Will This Cam Work?
Old Feb 6, 2001 | 12:46 PM
Vortex_89rs's Avatar
Will This Cam Work?
I need to pick a cam for my engine, but I am not sure if the one I want will work. The block is a 350 block from a 1970 truck. I was wanting the CompCams Xtreme 270 hydraulic roller cam, but it says the cam is for 87 and up engines. I want to use hydraulic roller lifters, but all the roller cams seem to be for newer engines. Can I use this cam on my engine? Will I need to fabricate anything if it won't work? Or would it just be better to go with normal hydraulic flat tappet lifters? This is going on a 383 with head ID# 378246. Thanks for any advice you provide!
Vman
1969 Camaro Sport Coupe
383, 700R4, leather, everything black but the lights
Previous owner of an 89 RS Camaro
2.8L V6, 700R4
Old Feb 6, 2001 | 01:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They make 2 series of Xtreme rollers, one is the "retrofit", the other is for the factory's mutation.
If you want the 87-up grind rather than the "retro" grind, they can easily do that, it's only like $25 custom charge.
Look on their web page fartehr down in the cam spec list. I think you'll find the other cam. I have its big brother XR282HR in my 400.
All you will need is the correct timing set, a cam button, the roller lifters, and pushrods that are .400" shorter than flat tappet ones would be.
Those heads would actually be 3728461, double-humps, right?? If so, you're going to have to do some major work-around to make up for their lack of accessory bolt holes. They're good heads other than that, and of course their pre-emissions design that won't run on pump gas with the CR that you'll have.
ICON Motorsports
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
masonta
Aug 31, 2015 10:14 PM
Fronzizzle
Aug 9, 2015 01:15 PM
