Plugs look like smores after intake swap.
Old Feb 6, 2001 | 02:04 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Well today when The car didnt start I pulled a plug (2) and found half of it was peral white, other side black and on the other side of block (3) was completely blackish. Is this from bad timing too much fuel pressure or back gaskets. Car does not smoke except on start up (valve seals)
Old Feb 6, 2001 | 02:59 PM
badbird88's Avatar
pearl white is an extremely lean condition but black is an extremely rich condition. Never seen one side lean and the other white....interesting. Is the car a TPI or TBI car or carb? If it was TPI I could see where one side could be different than the other due to the fuel injectors. If it is TPI I would look closely at the fuel injector for the cylinder that is running lean before you burn a hole in the piston or burn your valves up. Yes if they were all black I would look at lowering your fuel pressure.
1988 TA 300+hp 350 w/ TBI and Holley TB unit, Holley projection intake,
WC T-5, 3.42 gears w/ Auburn posi. MSD 6A, edelbrock TES headers, dynomax 3" cat and cat-back system, ACCEL coil, polyurethane bushings all around, aluminum driveshaft, Mr. Gasket open air cleaner.
1993 S-10 w/ 4.3L V6 TBI, slightly bigger cam, Mild polish job and 3 angle valve job on heads, Edlebrock TES headers, Dynomax cat back, MSD 6A, ADS chip
2000 Kawasaki KX 125
Old Feb 6, 2001 | 03:02 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Its a 89 350 TPI and I got brand new injectors.
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Jan 29, 2017 07:00 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
