going from hyd. roller to solid roller
Old Feb 17, 2004 | 10:00 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
what is differant between the cams?
Old Feb 17, 2004 | 10:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Depends.
If you are getting one made like the factory roller, just the lobe profiles.
If you are getting one like the pre-factory roller, the timing sprocket mounting and anti-walk provisions. And lobe profiles.
Old Feb 17, 2004 | 10:23 PM
Engine: ls1, LB9
so in general it is the profile not any harding? could you use a solid roller lifter on a aftermarket hyd. roller cam? I was all ways told no but, comp cams seems to be saying yes now. although they have given bad info in the past
Old Feb 17, 2004 | 10:51 PM
five7kid's Avatar
Really?
Hydraulics use different ramps than solids. Could you quote what Comp is saying that indicates they say you can use solid roller lifters on a cam made for hydraulic roller lifters?
Old Feb 19, 2004 | 06:23 PM
Engine: ls1, LB9
I will give them a call again, or better yet I will ask them in an e-mail so I can just past it here. the only problem is they like to say differant things every time you talk to them.
Old Feb 20, 2004 | 06:04 PM
Engine: ls1, LB9
well, this is my last responce...
I wouldnt recommend using solid rollers on a hydraulic roller cam, but you could probably get away with it.... what are the specs on the cam?
Andrew
COMP Cams
Old Feb 20, 2004 | 09:42 PM
85TransAm406's Avatar
Car: 1985 Trans Am
Car Craft did it and tested it, and it did work, they went from hyd. to the endur-x lifters and found no power gain, even when they played with the lash, moving it all the way to zero even. But in theory, the lash will make your cam a little smaller. And then they said they didn't reccomend it either.
Old Feb 21, 2004 | 02:15 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
as ive heard it:
technically you CAN run them, but the lash and such has to be set very precisely. do a search, this topic has been beat to death. If it were my choice, i would not use hyd. roller components on solid roller cams and vice versa. Like five7 stated, the ramp rates are different.
Old Feb 21, 2004 | 07:59 AM
Engine: ls1, LB9
I was looking for some one who would say it would damage things. oh well. I know someone who is doing this and I told him not to several times but, he does not listen. I guess I will just see what he wrecks when his already high lift cam .510 or more hits coil bind after his 1.6 ratio rockers are used with the solid lifters. plus he has a hard time with lashing as it is
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
kkirch15
Sep 30, 2015 04:44 PM
dusterbd
Sep 29, 2015 08:40 AM
