can i seal a hole in plastic???
Old Feb 17, 2004 | 11:32 PM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
i got a really really small leak in my power steering pump other then leaking fluid it works great. is there anything i can use to seal the leak (cover hole)??? maby some glue or a patch for tires or something along those lines, there gotta be something. any idea what i could use???
Old Feb 18, 2004 | 03:48 AM
Morley's Avatar
you could try JB Weld, but to seal it properly you really need to do it from inside, which means removing the pump, draining it and getting the area to be repaired VERY clean. Then there is always the possibility that the JB will break off and get in the pump or gear box and mess things up.
Old Feb 18, 2004 | 04:47 AM
ede's Avatar
ede
if you could figure out what kind of plastic it is you could glue a patch on it and it should be good as new.
Old Feb 18, 2004 | 08:06 AM
Vader's Avatar
If it's your pump reservoir, chances are it's glass-reinforced ABS. You can plastic weld that fairly easily, but it has to be removed, cleaned, and dried so there are no traces of oil remaining before the weld.
If you have the time to do that, it's worth a try. If not, you might want to get a used pump and switch reserviors (or entire pumps).
gta892000
Aug 11, 2019 11:16 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
katrav8
Sep 11, 2015 09:00 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
