Anyone with LT4 Hot, ZZ9 or or SLP cams step in....
Old Feb 6, 2001 | 01:15 AM
Dan87IROC-Z's Avatar
My question is concerning how your cars reasponded to these cams after installing them. Also, I'd like to know what mods you had on your car at the time of the cam swap?
The reason I ask this is because I am just getting ready to install my LT4 Hot Cam in my 87 IROC this weekend and I was wondering what to expect. My major mods are located in my signature. I also will be installing a 3.42 rear end here soon.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Feb 6, 2001 | 01:42 AM
Guest
Guest
Posts: n/a
I dont know how well I can really answer this, because I went from the LG4 to a 350 with TPI and the 224/232 SLP cam. What I can tell you is there is no way in hell you can run the hot SLP cam on a stock chip. I messed with stuff here and there and got it somewhat ok, but stock just doesnt cut it. IIRC the LT4 'HOT' cam has intake duration around 218, so it should do much better with the stock chip. We ended up swapping from a pathetic 2.41 rear to a 3.42, and that helped out alot.
Old Feb 6, 2001 | 12:44 PM
KevinP92Z's Avatar
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
I'll agree with madmax. I'm running the same cam. I just pulled the Fastchip for some fixing, and stuck the lowley Hypertech with GM calmap in. It lopes a bit, and smells pretty rich, but it does run. Timing is very conservative compared to the Fastchip. But for now I'm not setting codes.
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
Old Feb 6, 2001 | 12:46 PM
Thanks guys, anyone else?
Old Feb 6, 2001 | 02:10 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I'll let you know after this weekend.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 8, 2001 | 01:48 AM
back to the top!
GTAman
Mar 15, 2019 11:40 AM
80s Poncho
Aug 19, 2015 06:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
