what should i expect
Old Feb 21, 2004 | 01:46 PM
84_berly_84's Avatar
Car: 84 berlinetta
ok what should i expect with this set-up in my 84 berlinetta 305
crane energizer cam :
intake lift- 105 duration- 204 deg.
exhaust lift- 115 duration- 204 deg.
Intake @Cam 2847 @Valve 427
Exhaust @ Cam 2847 @Valve 427
Rocker Arm Ratio 1.5
flowtech headers
custom 2 1/2 in. y-pipe no cats to a hooker cat-back
edelbrock 600
also the engine is a fresh rebuild everything else is completely stock so what should i expect
Old Feb 22, 2004 | 12:20 AM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
not much
Old Feb 22, 2004 | 12:31 AM
Car: 84 berlinetta
thanks just the answer I was looking for
Old Feb 22, 2004 | 10:49 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
To put it in perspective, the L69 has a cam with 203°/207° duration, .440" something lift; and a 3" Y-pipe; and about a point more compression than your LG4. Same heads. So I'd guess you'll get a little less than a L69's 190 HP. Maybe 175-180 if you're real lucky.
Old Feb 22, 2004 | 11:31 PM
Car: 84 berlinetta
Thank-you
ZZ3Astro
Aug 13, 2019 12:57 AM
86z89iroc
Oct 5, 2015 01:04 PM
hartsmike
Oct 2, 2015 07:11 AM
80smetalfan
Sep 22, 2015 02:55 PM
BWilcox
Sep 20, 2015 12:19 PM
