Relays??
Old Feb 22, 2004 | 12:09 AM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Relays??
Hey guys My car is an 89 pontiac firebird and it had a 305 tbi motor in it and is 5-speed. Now I was wondering what all the relays on the drivers side firewall are?? I know the ones the fel pump cause i rewired it when i switched to carb. Thanks guys
Old Feb 22, 2004 | 12:10 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
i beleive one or two are for the electric fan
Old Feb 22, 2004 | 12:31 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Relays??
The Trickster can tell you....where is he?
Old Feb 22, 2004 | 12:32 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Well, there should be the fuel pump relay, MAF sensor relay, MAf sensor burn-off relay, Electronic spark control relay, and the headlight relay on the left fender.
Old Feb 22, 2004 | 12:33 AM
I knew you'd show up...LOL
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hey Picard,
check your six
Old Feb 22, 2004 | 12:35 AM
Hey Picard,
check your six
I have way more than six....
Picard out!
Old Feb 22, 2004 | 12:41 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Picard out!
Okay,
So I can't count. Make that six + 2 then.:lala:
Old Feb 22, 2004 | 10:59 PM
Car: 89 Formula
Engine: Carbed 5.7
well i don;t have a computer anymore and am running a carb so i guess I just need to leave the fuel pump and the headlight ones and i'm good. How can i tell witch one is for te headlights?thanks
Old Feb 22, 2004 | 11:25 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It's mounted above the left front tire on the sidewall near the hood hinge point.
Old Feb 23, 2004 | 12:03 AM
Car: 89 Formula
Engine: Carbed 5.7
Wait so its not mounted on the firewall??
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
