Grrrrrr...stuck valves..old timers?
Old Feb 22, 2004 | 08:38 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Yeah..in the flathead 6 I'm gonna put in my 3rdgen project..yeah, that's it...gonna put it in a 3rdgen...
How the heck can I get these out? Been loading the guides up with PB Blaster.
Any tricks I don't know of? I can't get the adjusters out, since all but two of the valves are closed, can't rotate the cam, since the valves are stuck in the danged block.
Thinking of chopping the cam up and taking it out in pieces, pulling the followers, and driving them out.
Might run this in my, er, uh 3rdgen for a year or two, then if it runs well, put it back in the forklift I just stumbled across
Old Feb 22, 2004 | 08:50 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Woops, not quite up there on the 'ole flatheads, maybe someone else. . .
RBob.
Old Feb 22, 2004 | 10:24 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
try soaking in kerosene it works for stuck pistons in bores and stuck lifters.. maybe it'll free up the vavles
the bitch part is emersing the whole thing
Old Feb 22, 2004 | 10:26 PM
Morley's Avatar
Well I would suggest a torch to heat it up, but not after kerosene...they may come out and never be seen again.
Old Feb 23, 2004 | 05:42 AM
ede's Avatar
ede
hose the valve down with some r134, it'll shrink them up a little and maybe break them free. BFH might work if the cam was out of the way.
Old Feb 23, 2004 | 06:23 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Both liquid wrench and break-free (or break-away) are great penetrants.
I left a frozen part soaking in diesel for 6 mo and still couldn't break it loose then tried break-free and it came loose effortlessly within minutes.
Is that flathead going to be EFI or carb?
Old Feb 23, 2004 | 01:54 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Yeah, gonna keep soaking down the stems, thanks for the replies.
Can't get the dang cam out until the valves are up.
EFI or carb? Guess I'll stick with the 1bbl for now...after all, who needs more than 105HP?
(BR)G-Machine
Aftermarket Product Review
Mar 16, 2004 09:20 AM
(BR)G-Machine
Mar 16, 2004 09:12 AM
wjbecker
Mar 13, 2004 06:21 PM
BOTLFED
Aug 8, 2003 12:34 PM
