cam change
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
cam change
I have an 89 305 TPI. I think it has the roller cam (correct me if i'm wrong) If i do a cam change will i have to replace the lifters?
I want to put a Speedomotive 383 in this summer and would like to know if i can use a roller cam and not have to buy new lifters for it
- 89 Formula 305 WS6
SFC's,
LCA's,
Air foil
Flowmaster cat back
Tranny Cooler
A/F Ratio Meter
Trans Temp (not a mod but it sure spurs interest) - 90 Eagle Talon 2.0
(winter beater)
Mods? HA! its a rice burner!
Guest
Posts: n/a
Depends on what block you use for the 383. If its a roller block, you could reuse the old lifters if they are not damaged. I would say if you are going to go to the trouble of replacing the crank, maybe rods, pistons, etc. and make a 383, why risk an old lifter?
