Flywheel problems???
Old Feb 24, 2004 | 12:25 AM
aberlinetta84's Avatar
Car: 84 Berlinetta
Engine: 305 LG4
I have an 84 berlinetta LG4, at certain times theres a strange metal sound (kind of like scraping on an edge), I have traced the sound and it looks like its coming from the flywheel itself? Can these go bad and if they can, how can I tell if it is or what it may be???
Old Feb 24, 2004 | 01:04 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
i'd be kinda shocked if you found a flywheel on that car.. anyhoo makes sure the converter bolts are tight against the flexplate (flywheel) while your under there inspect it closely and look for cracks..
Old Feb 24, 2004 | 05:45 AM
ede's Avatar
ede
flex plates, and fly wheels, crack. flex plates tend to make a lot of noise when they break or crack.
Old Feb 24, 2004 | 09:51 AM
Car: 84 Berlinetta
Engine: 305 LG4
why would you be shocked to find a flywheel on my car, 89? Ede, could it not always make noise, it seems to start whenever it wants to and then seems to slow down and stop for a while..
Old Feb 24, 2004 | 10:07 AM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
flywheel is on a manual transmission
flexplate is on a automatic transmission
Old Feb 24, 2004 | 10:44 AM
89RsPower!'s Avatar
a cracked flexplate wont stop making noise once it starts and they only get louder.. still do the usual.. visually inspect it.. make sure the bolts are tight make sure the inspection cover isnt hitting.. while your at it you might wanna check your heat shields out a loose one could make some noise, especially if its the one on top of your cat with a few broken welds.... just a thought.... try to be a little bit more descriptive about the problem.. are you positive thats the area its coming from? does it very with rpm? does it very under different types of load?
Old Feb 24, 2004 | 11:16 AM
ede's Avatar
ede
why would you think i'd be shocked to find a fly wheel in your car? i never said anything like that?
Old Feb 24, 2004 | 11:34 PM
Car: 84 Berlinetta
Engine: 305 LG4
sorry, it does vary with rpm, it is coming from the flywheel/flexplate location...it seems to be non-intermittent, it just starts making the noise for about 10 to 15 mins and then seems to slowly stop and go back to silent, and one last thing, it doesnt have an inspection cover, I have no idea why?
Old Feb 26, 2004 | 06:23 PM
Car: 84 Berlinetta
Engine: 305 LG4
any ideas? Im getting frustrated by this sound since it only does it randomly when it wants to
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stangski09
Nov 14, 2015 01:27 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
