Fuel Leak somewhere around tank
Old Feb 24, 2004 | 03:22 PM
Fairly Strange's Avatar
Car: '89 Formula
Engine: 305 TBI
Just replaced the fuel pump 4 weeks ago. Checked tank at the time...no rust, no holes. Install went smoothly and I installed a fuel pump access panel while the tank was out.
Now, starting about a week ago, I've got a fuel leak. It drips out the back edge of the rearward heat shield. I can't tell for sure where its' coming from( definitely not the sides or bottom)but I have noticed that it occurs primarily while the system is under pressure.
Is it possible that I have developed a pinhole in the pressure or return lines?
Just looking for opinions before I tear into it.
Thanks!
Old Feb 24, 2004 | 09:02 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
If you take off the gas cap does it relieve pressure? If you take off the cap and use a flashlight look at the top of the tank if you see run marks on the top it is a seal or a line that is not tight. Turn the key ot run but not start and look for gas. mine was a pin hole leak in the filler neck i used apoxy to fix it. You can use the access in the fended to do most the work.
Old Feb 24, 2004 | 09:55 PM
3rdGenBlackBird's Avatar
Should taking off your gas cap always relieve pressure? Are there normal conditions that it wouldn't/shouldn't do that? Do mechanical fuel pumps vs electric make a difference?
Old Feb 24, 2004 | 09:58 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
You probably caused a crack where the filler neck meets the tank. They are very susceptible to cracking in that spot. In fact mine has a pinhole leak there. There was also a bulletin for it.
Old Feb 24, 2004 | 11:09 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I would look at the o-ring and locking ring around the sending unit first. Just a thought!!!!!!!!!!!
Infested
May 22, 2018 11:56 PM
Andrew6.688
Dec 13, 2015 10:59 AM
theurge
Aug 21, 2015 12:46 PM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
