Can you put an LT4 roller hot cam into an older non roller 350 block??
Old Feb 24, 2004 | 04:50 PM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
I know you can put aftermarket roller cams into an older 350 block, but can you put factory roller cams like the LT4 cam into an old 350 block and use conversion lifters and a cam button?? I want to put one in my girlfriends T/a because it goes through hydrualic cams about once every 6 months, tired of having break in problems and worn out lobes.
Old Feb 24, 2004 | 05:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You can use one if you use the late-model timing set and some sort of something to simulate the thickness of the retainer plate, and of course a cam button.
If the block eats cams, it probably has The Lifter Bore Problem, where some of the lifter bores don't point at the cam like they're supposed to. Don't count on a roller cam necessarily fixing it (although it might as long as they're all at least perpendicular to the cam axis).
Old Feb 24, 2004 | 08:35 PM
cgb's Avatar
cgb
Yup you can use 'em....but you still need the retro fit roller lifters. Lingenfelter sells the stuff you need for the cam install....
And if it's eaten that many cams, you more than likely have other issues to worry about, as stated.
Old Feb 24, 2004 | 08:39 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
if its eating cams, would you assume the lifters are sticking?
Old Feb 24, 2004 | 09:33 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
About the Lifter Bore Problem..
Is there a backyard method of checking that?
Or does it need to be checked at a machine shop?
Is it one lifter bore in particular?
Thx
midge54
Dec 27, 2019 04:14 PM
Reborn756
Sep 4, 2015 03:42 AM
camaro71633
Sep 1, 2015 10:24 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
