rate the hp for this setup
Old Feb 25, 2004 | 03:15 AM
chad89ta's Avatar
750 holley dp victor jr intake 406ci motor with je pistons 10.5.1 afr heads 210cc intake runners 100%cnc ported combustion chambers 100%cnc ported intake ports,2.08 and 1.60 valves,comp cam extreme 294, 250 256 @.50 and 519 524 lift,i will be using 1.6 full roller rockers so the lift will go up,all so msd probillet dis hei msd 6al with blaster 2 coil,,,,,,what kind of power do you guys think this will make,,,,,,,thanks
Old Feb 25, 2004 | 07:31 AM
chad89ta's Avatar
y does it say moved
y does it say moved
Old Feb 25, 2004 | 09:28 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: y does it say moved
Originally posted by chad89ta
y does it say moved
Because it is a tech/opinion question and nothig to do with racing.
Old Feb 25, 2004 | 10:41 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Hard too say for sure, Desaktop dyno seems pretty good at guessing.
Maybe 450-500hp at the fly.
Old Feb 25, 2004 | 12:07 PM
87LS's Avatar
Car: 87 Camaro LS
Engine: LG4
Transmission: T-5 World Class
Axle/Gears: 3.08 Open baby!!
I think youwould get more than that
I think more like 550, thats alot fo compression and those heads are sick
I would put a 2 inch carb spacer pesonally, thats just me
Also a bigger cam
AJ
Old Feb 25, 2004 | 04:53 PM
85_camaro's Avatar
i would also say you need more cam.. you have a lot of ci and an intake for a high rpm set up, and you heads/intake/carb are going to flow good enough for a large roller cam. which is going to boost power more. but to answer your question with your current set up. i would say 450-475 i think a larger roller cam would wake up the power a lot.. because your setup is already set up for one...IMO...have fun
Old May 16, 2004 | 08:13 PM
HesterZ28's Avatar
Car: 97 30th Z28
Engine: lt1
Transmission: 4l60e
I say 490 fly hp...... Still not even close enough
Pac J
May 17, 2020 10:44 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
2012sergen11
Oct 13, 2015 07:38 PM
customblackbird
Oct 1, 2015 04:30 PM
tattmann
Sep 27, 2015 05:20 PM
