Important question, please help!
Old Feb 9, 2001 | 09:49 PM
StCr19's Avatar
Car: 1991 Galant VR4
Engine: 2.0L 4G63 Turbo
Transmission: 5sp transaxle/transfer case
Did Chevy use the same heads for the L98 and the 305 TPIs? Also, what is the max lift for these heads?
I know they used the same intake with different injector sizes, I heard they used the same heads.
BTW, what is a 305 TPI's proper designation?
[This message has been edited by StCr19 (edited February 09, 2001).]
Old Feb 9, 2001 | 09:56 PM
ede's Avatar
ede
i believe the l98 heads are larger across the chamber, or another way there is more metal between chambers, and uses larger valves than a 305. the max cam lift is in the .47 range.
ICON Motorsports
1st & 3rd
Old Feb 9, 2001 | 10:01 PM
Macgyver's Avatar
The L98 used 64 cc 1.94 1.50 heads
The LB9 (305 TPI) Used 50-something cc heads with smaller valves I can't remember right now
Old Feb 9, 2001 | 10:09 PM
R.O.B.'s Avatar
LB9 is the term for 305 TPI.
They come with 58cc heads, with 1.84/1.40 valves.
L98 is the term for 350 TPI.
They come with 64cc heads, with 1.94/1.50 valves.
Rob
'86 TA 305 TPI
Gutted MAF
Ported Plenum
TB Bypass
Old Feb 9, 2001 | 10:26 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by StCr19:
D...BTW, what is a 305 TPI's proper designation? </font>
I believe the original factory RPO had to be shortened because it didn't fit the three-character format. The original RPO designation was something like "ANCHOR"....
Hey, don't argue with me - I've GOT one. O.K! (Actually, it could be worse, but Metallica's next verse should have been "Gimme cubes, Gimme tires, Gimme cams that lift 'em Higher")
Later,
Vader
"I know how to solve your problem, but I can't tell
you since you might use the information illegally...
Adobe Acrobat Reader 4.0
Old Feb 9, 2001 | 10:52 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
<font face="Verdana, Arial" size="2">Originally posted by Vader:
</font>
Y'know, I come on here in the sparse moments I have to myself to relax, and I invariably come across these seemingly mundane threads, and just as invariably (maybe I should take this as a hint?) I come across a 'VADER' post that has the eldritch effect of causing me to loose conscious control of my beverage and, as always, winds up in either my keyboard, or on my monitor...
but ya know what big V? I had just finished! So there...
Now how do I get the burn to stop in my nose?
Old Feb 9, 2001 | 10:55 PM
Macgyver's Avatar
Vader makes me want to use big words
BTW, 2000th post
Old Feb 10, 2001 | 11:30 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
wasn't L98 a corvette aluminum motor and L89 is the 350 TPI in cam/fbds?
Old Feb 11, 2001 | 12:04 AM
Vader's Avatar
Joel,
To my knowledge, teh L98 designation was for either the iron case/aluminum head engines used in the Corvettes ('Y' body) or the iron case/iron head engine used in 'F' cars. This is very similar to the LT1 designation being used for both the iron and aluminum-headed engines used in several platforms.
I don't recall seeing the 'L89' designation for a GM engine. There was an 'L80' but it was a 152 CID V-6, and an 'L69' that was a 305 carbed HO,
Later,
Vader
"No matter how hard you try you can't stop us now..."
[This message has been edited by Vader (edited February 10, 2001).]
92GTA
Apr 9, 2016 07:39 AM
E_S
Aug 29, 2015 04:09 AM
redmaroz
Aug 16, 2015 11:40 PM
Ozz1967
Aug 16, 2015 10:23 PM
gta power
Aug 13, 2015 06:15 AM
