Power problems
Old Feb 25, 2004 | 04:40 PM
Wookie768's Avatar
Power problems
i had a altinator problem with my camaro it look old anyways so i went ahead and replaced it and along the battery too just in case
the problem was that the battery was not charging back up and when i disconected the battery from the car while it was on the car would just cut out
so now that my altinator and battery is changed in the car something weird is going on
right now i know the altinator belt isnt on tight enough because when it kicks in it sqeals but when it does the voltage gauge jumps to 18volts been like this for a few days i would start it up
i havnt heard the belt sqeal for a day or two now and my voltage is at 9-8 volts and i may have to jump it because it did not start just now so is my altinator working anymore? should i try to tighten the belt? could that be the problem
Old Feb 25, 2004 | 05:40 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
I wouldn't take the dash voltmeter reading as gospel, get a proper reading with a digital meter across the battery terminals.
If the belt stopped squealing by itself, it may have gotten a shiny surface from slipping too much previously...check your belt tension before you tighten it, it should give no more than about 3/4 inch in the middle. You'll have a hard time over-tightening it unless you're trying to.
Old Feb 25, 2004 | 06:05 PM
Wookie768's Avatar
well i dont think the altinator is charging it back then
i was lettting the car warm up and i started to turn everything on lights radio ect and saw the gauge go down a little bit
i turned every thing off and shut the car off
tried to start it again but it wouldnt turn so im like f*ck it ill jump it tommorrow
jhawkeye
May 25, 2022 06:33 PM
355tpipickup
Aug 27, 2015 08:13 AM
neekolzun
Aug 24, 2015 04:59 PM
Bert87
Aug 23, 2015 03:50 PM
db057
Aug 22, 2015 08:17 PM
