What do I do for a good intake gasket seal?
Old Feb 9, 2001 | 04:09 PM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
I've never done a V8 intake gasket before. I know there is two gaskets, one for each head. Do I just put sealant around the water jackets and between the two heads and then put the gaskets on? Any info here is appreciated. I know there is a tightening sequence already though.
'89 Formula 383 TPI
Old Feb 9, 2001 | 04:14 PM
Jason M 91Z's Avatar
I use some copper spray around the intake ports, and Permatex Ultra-Grey around the water jackets and down the block rails. Its the same stuff GM uses on their crate motors so it has to be decent. I haven't had one leak yet.
Also, use some teflon paste around the intake bolts that go into the lifter valley so you don't get that annoying oil seepage around the bolt heads after a few miles.
-Jason M. 1991 Camaro Z28
Old Feb 9, 2001 | 06:13 PM
ede's Avatar
ede
if there are any pits in the head or intake i use a little permatex ultracopper around the water passages and use k&w copper spray on sealer on the long intake gaskets. if the engine is on a stand i use a punch and make punch marks all along the front and rear ends walls of the block as well as the intake and use the factory rubber gaskets with ultracopper on the ends where they meet up. if it's in the car i use ultracopper on the ends too, lay a 1/4" bead dow nand let it sit about 20 minutes and install the intake. i've never had problems with either method ,but it's hard to see if the rubber seals move with the engine in the car. i've never saw the ultra gray, or what ever it's called but i'd like to try it, not heard anything but good about it.
ICON Motorsports
1st & 3rd
Old Feb 10, 2001 | 11:21 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
All the tips above are perfect. If you get a intake gasket set with end seals, throw them in the garbage and use silicone. Trust me on this one!
Old Feb 11, 2001 | 12:27 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
I use ultra blue around the water jackets - just a small 1/8" bead or so - high tack to keep the gaskets in place, and a big fat 3/8" bead or so of the right stuff for the end seals. If you don't want to pay $15 for the right stuff just use the ultra blue on the ends. I've never had leaks with that stuff. Also, I used permatex b2 non-hardening silicone on the bolt threads. Basically if you take anyones advice that's posted so far you'll be fine. Another thing that would help is to buy new intake bolts, then cut the heads of 6 of your old bolts - then put the homemade studs in one of the heads and use them to guide the intake down after making the end seals. Once it's down, put in six of the new bolts on the other side finger tight and then replace the "studs" with the other new ones.
Base: 89 Iroc-Z LB9 auto 2.73 posi
Exh: 3" Dynomax muffler, 3" Pipe in place of cat
Ign: GMPP 8MM wires, Accel cap&rotor, AC Plugs
Fuel: Cleaned and flow-matched injectors, afpr, !air pump&diverter valve
Sound: Clarion deck, Kicker speakers and amps
Suspension/Drivetrain: KYB Shocks, BMR Strut Tower Brace
Misc: TB Bypass, All synthetics, Flexlite Transmission cooler
On the way: flow tech headers, alum. driveshaft
"Deserve's got nuthin' to do with it..."
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NinjaNife
Aug 23, 2015 11:49 AM
Navy8125
Aug 21, 2015 09:32 AM
