HELP, MOTOR SWAP FUEL PUMP SHUTS OFF
Old Feb 9, 2001 | 11:33 PM
Brandog87GTA's Avatar
What controls the fuel pump? It will cut on and then cut off, how can I get it to stay on????PLEASE HELP!! I am so close to finishing my motor!
Old Feb 9, 2001 | 11:41 PM
Enkil's Avatar
If I'm not mistaken.. the fuel pump SHOULD cut off after a few seconds, unless the engine's running.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Feb 9, 2001 | 11:52 PM
Yeah well I switched from TPI to carb so it wont stay on now, how can I get it to stay on? Is there a relay or is it computer controlled? I am using no computer anymore
Bright red 87 GTA with 350 tuneport. Basic mods such as K&N filter, Flowmasters, Wells MAF, TPIS air foil, Accel 8.8mm plug wires with , Accel distributor cap and rotary buttons.Gutted cat. B&M Shift kit, 100HP shot Nitrous, soon to change over to carburator.
Old Feb 10, 2001 | 12:25 AM
Someone help please
Old Feb 10, 2001 | 01:47 AM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
Read my response in the exhaust section
White 92 RS,388 cu.in.N/A
3.73 gears,auburn posi
Best 60 ft : 1.97
Best 1/4 : 12.679
Steve Spohn
Rear Suspension
Autometer guages
Extremely Loud Stereo !
Driven Daily
HOOKER LT's SOON!!! & 4 inch Exh.
Old Feb 11, 2001 | 01:48 AM
BenDoe's Avatar
i don't know if you have one, but it could be the oil pressure sending sensor near the oxygen sensor on the driver side. It sends the oil pressure to the fuel pump. It case of an emergency, it will shut the fuel pump off.
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218 the usual street racer with a stock chip.
Cars beaten as of 01/01/01
95 Acura Legend
Lost to as of 01/01/01
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
djmarch
Aug 9, 2015 05:27 PM
