How much is too musch CR??
Old Feb 11, 2001 | 01:22 AM
nelliesIroc's Avatar
I'm looking into buying an engine kit and it comes with 10.3:1 pistons. My question is can I run this compression on pump gas? or what is a good ratio to shoot for?
Old Feb 11, 2001 | 08:20 AM
ede's Avatar
ede
that is getting near the upper limit most people consider for pump gas and iron heads. each engine is differant and has differant needs but you shouldn't have any problems with that set up.
ICON Motorsports
1st & 3rd
Old Feb 11, 2001 | 09:18 AM
Biochem's Avatar
Car: 2002 SOM z28
That is about as high as I wouold go even with aluminum heads. Some go higher. Like Ede said, each engine is slightly different too.
Timing (base, rate of advance, etc) has a big influence on detonation too...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Feb 11, 2001 | 09:34 AM
82 TRANS AM's Avatar
Car: 82 T/A WS7
Engine: Pontiac 400
Transmission: Muncie 4-speed
If you go with that kit get the Fel-pro teflon head gaskets or a premium quality heat gasket thats a little "fat". Agree, 10:1 is about the limit for the street but small blocks heve a lot of leeway depending on the rest of the set-up. Get the best ignition you can afford. This will pretty much assure an occasional fill up of bad gas won't hurt much.
Kenney
82 Trans Am WS7 notchback
83 Trans Am WS6 T-tops
72 Vista Cruiser 455
90 Olds Trofeo
80 K-10 w/snow plow
Painter @ Chevy dealer
GM junkie
Old Feb 11, 2001 | 10:42 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Where you live also plays a part in the compression limit. A car that pings with the best pump gas at sea level will run fine at a higher elevation like Denver.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Feb 11, 2001 | 11:33 AM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
The compression ratio you can run without problems also ties in to your camshafts duration figures. The longer the cams duration numbers, the higher static compression you want to run. That's because the valve opening and closing events create a "dynamic compression" ratio which is somewhat lower than the static compression normally calculated by the standard formulas. Essentially, if the intake valve is still open when the piston begins it's upward compression stroke, you really don't get all of the full compression on the gas mixture. Dynamic compression ratio is typically calculated from the intake closing point on an engine, and this point depends on the camshaft's duration.
If your camshaft has high duration numbers, you can run higher static compression. If your camshaft has low duration numbers, you need to stick with lower static compression.
89 IROC with lots o' stuff
84TA305
Mar 20, 2003 02:04 PM
84TA305
Mar 19, 2003 04:31 PM
Dragula
Apr 23, 2002 07:45 AM
