I wanna build up my ignitions system, need some recommendations.
Old Feb 11, 2001 | 05:16 PM
mostafa3k's Avatar
This is an often forgotten part of the car which can help HP and torque ALOT. I'm going to replace almost everything except for the distributor. Here's my list:
Ignition module
Cap & Rotor
Coil
Spark Plugs
Wires
What are your recommendations? I've heard good things about the MSD-6A and the Accel coil, also bosch platinum plugs. Any other good ones? What are your recommendations on wires? And where can i find the best prices?
BTW, I have a '91 RS TBI, which is completely stock. I will be doing dynomax exhaust and open element along with it.
Old Feb 11, 2001 | 05:38 PM
ede's Avatar
ede
you'll get a differant answer from everyone you ask, but that's what i'd do and use. for wires the next set i buy will be msd, for no real reason. i've used cheap accels, accel 300+, moroso blue max. some cheap solid wires, ac/delcos, beldons, and a lot more and all have worked well. big thing is to keep them off the headers and away from heat.
ICON Motorsports
1st & 3rd
Old Feb 11, 2001 | 11:14 PM
87RS402's Avatar
I'd get the MSD 6AL It's got the built in rev limiter and can save your bacon in the event of a missed shift or something lets go and the rev's skyrocket
Old Feb 11, 2001 | 11:46 PM
JJ's Avatar
JJ
My carb getting stuck wide open once made me order the MSD 6AL very quickly . . . nice safety protection, especially with NO2 and a manual.
Old Feb 12, 2001 | 12:01 AM
mcconahay37's Avatar
I have the Crane Hi-6 ignition. It also has the built-in rev limiter like the MSD 6AL. It was an easy install and made quite a difference. I also have an Accel supercoil. Since installing these, I've had zero problems.
Old Feb 12, 2001 | 12:16 AM
BlckLblSociety5's Avatar
MSD Digital 6, HVC Blaster Coil, MSD
Superconductor Wires, MSD Flying Magnet Crank Trigger.
Old Feb 12, 2001 | 12:19 AM
NGK Iridium IX Spark Plugs
Old Feb 12, 2001 | 12:21 AM
Want to spend the big bucks get an MSD Digital 7 Ignition Control
Old Feb 12, 2001 | 12:59 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
I have everyting MSD except for the distributor..
MSD 6AL
MSD cap and rotor
MSD blaster coil
MSD super conductor wires
teh BEST qualitya nd the BEST service...i would recommend them to ANYONE. you wont be sorry if you go with MSD.
as far as spark plugs...forget about the special platinum ones...they are usually nothing more than a marketing scheme..they dont really do anything any better than an SC Delco $.99 would do. not on our cars at least. now if it was an M3 or somthing then maybe.
I was gonna go with regular old AC Delco plugs for my crate engine, but I couldn't find the ones that GM recommended ANYWHERE, so I went with the AC Delco Rapidfires. they work well for me. a coupel buddies have them and they love them.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Intake, Holley 670 CFM TB, Edelbrock Water Pump, March Pulleys, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Cap and Rotor, Rapidfires, Hypertech Fan Switch & Chip, SLP 1 3/4" Stainless Headers, 3" Cat Back, Flowmaster 40 Series
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
GM 10 Bolt -coming soon Auburn Pro Series Differential, Richmond 3.73s
Brian's 1991 RS Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
BRoss99
Aug 10, 2025 05:08 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
