oil in tpi runners
Old Feb 28, 2004 | 10:52 PM
ar_mcadams's Avatar
Car: 91 camaro
Transmission: auto 700r4
oil in tpi runners
my car has a problem that I cant figure out. Im getting a oil film on the inside of the intake. Evenly spread throughout all the ports and a light ash deposit on the plugs. If the rings were not sealing good would this make oil film on the inside of the intake? Any one ever seen this before?
Old Feb 28, 2004 | 11:29 PM
screamin' 85 z's Avatar
Car: 85 IROC
Engine: 355 CI n/a
Transmission: 700 r4 w/3500 Coan
probably a result of blowby...The pcv breather ( the hose coming out of your valve cover) goes into the throttle body. Any oil blowing out of your pcv will get sucked into your intake. Excessive blowby is the result of worn rings / cylinder walls
Old Feb 29, 2004 | 12:15 AM
ar_mcadams's Avatar
Car: 91 camaro
if it is blow by how is is blowing into the intake? thanks
Old Feb 29, 2004 | 01:58 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Its not getting blown into the intake. It is getting sucked into the intake by the manifold vacuum. Try installing an inline fuel filter in your PCV hose. Vacuum will still be able to draw through it, but the oil and residue wil get caught in the filter, preventing it from entering your intake. I run a clear Spectre filter so i can see when i need to replace it.
89GTAOz
May 16, 2020 09:31 AM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
Sanjay
Aug 12, 2015 03:41 PM
