pushrod and roller rocker questions
Old Dec 15, 2002 | 09:12 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
First question: I have a '91 Vette L98 with the factory aluminum heads. They have guide plates, so that means the rockers are NOT self aligning, correct? If so, can I use roller rockers that say they're intended for SBCs up to '87? Iron headed engines went to SA rockers in '87, right (except the vette ones)? Who makes some not too expensive steel roller rockers? My car's driven daily so I dont' want to get aluminum ones.
Second question: Back in March, I had to replace my pushrods, I got these chromemoly ones:
http://store.summitracing.com/partdetail.asp?part=6393
I only now realized that they say "The pushrods are heat treated for use with guideplates" and that they're not 'hardened steel' which is what everyone says you need when using guide plates. I just want to make sure these are ok for my engine.
Old Dec 15, 2002 | 10:35 PM
radiateu2's Avatar
roller rockers
try enginekits.com give them a call very reasonable
Old Dec 16, 2002 | 12:55 AM
Car: '87 Camaro LT
Engine: 355 L98
Re: roller rockers
hey thanks! they have exactly what i want on sale! http://enginekits.com/specials/specials1.html
man i wish i had 200 bones to spare at the moment, maybe they'll go on sale again when i have the cash
Old Dec 16, 2002 | 01:06 AM
radiateu2's Avatar
hey Ukraine
they are on sale thru Dec maybe for x-mas hah lol your welcome they have quality stuff too. I bought all my engine stuff there. all the parts for a 305 to rebuild was less than 200 dollars I rebuilt my motor for 350 including machine work.
Old Dec 16, 2002 | 01:07 AM
MarkB's Avatar
Car: 1982 T/A -1986 Z28
Engine: 383 -305
Transmission: T56-700r
pushrods are fine....and whats the prob with using aluminum roller rockers for everyday use? you wont see a problem with them. they'll last forever. i used a set of crane golds on my transam for more than a year...
look in summit or jegs..they have very reasonably priced 1.5 and 1.6 roller rockers for under 200 bucks some of them are as low as 130
Old Dec 16, 2002 | 01:13 AM
radiateu2's Avatar
al rockers
Although I have never used them and never will. The aluminum rockers are inherantly weaker and several people on this board have used them with breakage under even normal conditions. Jegs and Summit doesnt always sell just quality items. That is my opinion though. Dont get caught up in the names of these places and sometimes you can get better deals somewhere else like enginekits.com and northern autoparts or even PAW
Old Dec 16, 2002 | 01:16 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
The more common aluminum rockers should be just fine for a daily driver. Just so your daily drive isn't WOT all the way! But if you want the steel ones, those look to be pretty decent.
As for the pushrods, they're fine. Steal is hardened by heat treating it. I would say that the rods you have are hard enough fo street use.
I should add this: Make sure to get a quality rocker. THe cheaper ones are prone to breakage, etc... Also, the cheaper ones are usually less accurate on the amount of lift the provide at the valve. Myself, I'll be using the GMPP 1.6 aluminum roller rockers. I got a pretty good deal on a set on Ebay.
Old Dec 16, 2002 | 12:35 PM
Vader's Avatar
If those are forged SS rockers, that's a pretty good price. Anyone who has a set of these is welcome to give us the details (please).
Old Dec 16, 2002 | 01:16 PM
Car: '87 Camaro LT
Engine: 355 L98
since they're self aligning, if i removed my guide plates i'd be ok to use them right?
Old Dec 16, 2002 | 06:48 PM
JP84Z430HP's Avatar
Car: 84 Z28
You deifnately DON't want the guide plates in there if you use the self aligning rockers, so, in a word, YES.
Old Feb 25, 2004 | 01:07 PM
Car: '87 Camaro LT
Engine: 355 L98
back from the dead...
that page for the roller rockers that are on sale is still up so maybe they still have them for that price, i forgot to ask when i called. but in their new catalog they have some other stainless rockers for $199. there's no picture but the guy on the phone said they're forged from 4130 stainless and they haven't had any complaints about them. he said they're made by an aftermarket company called CAP. page 13: http://www.enginekits.com/catalog.pdf
think those'll be good?
Old Feb 25, 2004 | 01:20 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If they're what I've been seeing everywhere else at that price, they're "CAT" brand... Cal Auto Tech. Made in China.
Beyond that, I know nothing about them, and have never used or even seen them in the flesh.
Draw your own conclusions.
Old Feb 25, 2004 | 01:25 PM
Car: '87 Camaro LT
Engine: 355 L98
oh, maybe it was CAT, I couldn't hear him real well. decisions, decisions...
Old Feb 25, 2004 | 01:42 PM
ede's Avatar
ede
if you don't want the full trunion rockers the roller tip from comp are hard to beat.
Old Feb 25, 2004 | 01:49 PM
Car: '87 Camaro LT
Engine: 355 L98
are you referring to the stamped roller tipped ones? are they susceptible to flex like the factory stamped ones or would there actually be an improvement?
Old Feb 25, 2004 | 02:27 PM
ede's Avatar
ede
very big improvement of stock
Old Feb 25, 2004 | 05:56 PM
DM91RS's Avatar
Car: 91 RS
Comp Cams 1318-16 Comp Cams Pro Magnum Roller Rockers™, 1.6 Ratio, Roller Tip, Self Aligning, Long Slot. For 1988-up with self-aligning rockers and 3/8” stud.
$220.00 ea
Ordered 2 sets at this price.....was this a good deal?
Old Feb 25, 2004 | 06:53 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
$220.00 ea
where did you get them from?
that is $110 cheaper than anywhere i have seen.....
Old Feb 25, 2004 | 08:17 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Re: pushrod and roller rocker questions
No your rocker arms are still self aligning. The guide plates that came on Corvettes are not true guide plates; they are not hardened and they have a wider gap then a standard guide plates. GM put them there because Corvette heads do not have guide plates built into them like the iron heads that came on Camaros with self-aligning rocker arms.
These are made for guide plates, they are fine. In fact I am buying the same ones.
Old Feb 28, 2004 | 08:15 AM
DM91RS's Avatar
Car: 91 RS
Sorry I missed this earlier..... www.salleechevrolet.com
DM
Old Feb 29, 2004 | 04:13 AM
25THRSS's Avatar
I just did a search on those and the price comes up as $268.22. How did you get em for $220? That is a killer price. Care to sell me the other set?
Old Feb 29, 2004 | 05:58 AM
DM91RS's Avatar
Car: 91 RS
You are right.....that "was" a killer price. Just checked and they are not on sale anymore. Sorry
Oh..and I'm using both sets on engines.
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
