How do you check for vacume leaks?
Old Feb 12, 2001 | 10:11 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
89 350 TPI Thanks
Old Feb 12, 2001 | 11:06 AM
HIX5000's Avatar
While the car is running take a can of carb/throttle body cleaner and spray along your vacuum lines if you hear the engine rev up you found a leak.
Old Feb 12, 2001 | 03:09 PM
87RS402's Avatar
I prefer to use a plumbers torch ( the propane type ). Don't light it, just turn it on and point the tip around and when you hear the rpm's come up like hesaid you have found the leak. Carb cleaner is a slightly corrosive flamable liquid and I don't like having any liquids on my engines. The propane is a gas and dissapates quickly so a backfire in a carb car won't blow up in your face
Old Feb 12, 2001 | 04:58 PM
JETHROIROC's Avatar
Don't forget to spray around the throttle body gasket, runner gaskets, etc. in addition to the vacuum hoses.
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
bamaboy0323
Sep 3, 2015 06:07 AM
perZ
Aug 21, 2015 05:51 PM
