Look at this...what's wrong?
Old Feb 12, 2001 | 07:15 PM
Bulldog92's Avatar
Car: '92 Camaro RS
Engine: 350 H.O.
Axle/Gears: 3.73 posi
OK, I need some help. I just changed my plugs and wires and the car is running horribly. Take a look at this diagram of the engine and distributor and tell me if it's wrong. I don't know if I've got the firing order right, but what really matters is that everything matches up by the numbers.
I've got to drive this thing to work tomorrow, so get back to me ASAP...thanx
1992 Camaro RS
305 TBI, 5-Speed
K&N open element, Hooker exhaust
http://www13.brinkster.com/scbaeb/camaro.html
scbaeb@hotmail.com
[This message has been edited by Bulldog92 (edited February 12, 2001).]
Old Feb 12, 2001 | 07:17 PM
ede's Avatar
ede
if it ran better before you worked on it then rechack all you did. plug gaps, wire condition, and correct order. the firing order for sbc is 18436572
ICON Motorsports
1st & 3rd
Old Feb 12, 2001 | 07:18 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
I don't see a picture.
1-8-4-3-6-5-7-2 clockwise.
I always get 5 and 7 mixed up.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Feb 12, 2001 | 07:24 PM
Bulldog92's Avatar
Car: '92 Camaro RS
Engine: 350 H.O.
Sorry about the pic...I fixed it. I appreciate the firing order sequence and that it goes clockwise on the distributor, but that doesn't help much without knowing what number corresponds to what cylinder on the engine and where you start counting clockwise from on the distributor. I'm just a novice on this stuff...still learnin'. Check out the graphic...is it correct?
Old Feb 12, 2001 | 07:28 PM
ede's Avatar
ede
the odd numbered side is on the left, even on the right, lowest number to the front you have it backwards it seems
ICON Motorsports
1st & 3rd
Old Feb 12, 2001 | 07:32 PM
Bulldog92's Avatar
Car: '92 Camaro RS
Engine: 350 H.O.
ede, I think I do have odd on the left and even on the right...do you mean the other way around?. Don't worry about that, though. What I'm concerned about is if, for example, #2 and #2 match up. Any thoughts?
Old Feb 12, 2001 | 07:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Front left is #1, odd #s are on the left, #2 is front right.
On the distributor cap, the one that is just to the left (driver's side) of straight ahead is #1; they go clockwise frome there. Order is 18436572 like it says on the intake.
Looks to me like you have the ones labelled "8" and "4" in your diagram exchanged. Those are actually 3 & 7.
ICON Motorsports
Old Feb 12, 2001 | 07:37 PM
ede's Avatar
ede
the cars left, not yours
ICON Motorsports
1st & 3rd
Old Feb 12, 2001 | 07:43 PM
Blue92's Avatar
Sorry, read your other post and you had already done what I suggested
[This message has been edited by Blue92 (edited February 12, 2001).]
Old Feb 12, 2001 | 08:00 PM
Bulldog92's Avatar
Car: '92 Camaro RS
Engine: 350 H.O.
IT'S RUNNING GREAT NOW!!! I had #3 and #7 crossed up...thanx for the help. It runs better than ever with Moroso Blue Max ignition wires and SplitFire plugs. Here's the correct diagram in case it will help anyone else:
Thanks again.
1992 Camaro RS
305 TBI, 5-Speed
scbaeb@hotmail.com
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
