Codes 32 & 33 after GM top end cleaner
Old Mar 1, 2004 | 12:48 AM
joshwilson3's Avatar
Old Mar 1, 2004 | 10:22 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
For code 33 im getting a map sensor circuit failure. You can try and replace the map and see if that works.
Old Mar 21, 2004 | 01:27 AM
Annihilator's Avatar
Car: Caprice
Engine: 5.0 305 LO3
Transmission: 2004-R
With regards to the code 32, your egr is most likely not getting enough backpressure as before so its not working correctly while cruising in OD. I have the same problem after putting dual exhaust on my '89 Caprice LO3.
Adam
Old Mar 21, 2004 | 03:05 AM
doubleogee's Avatar
i also pop the egr code when cruising in od....headers and duals...any way to solve that?
Old Mar 21, 2004 | 04:56 AM
Car: Caprice
Engine: 5.0 305 LO3
Well you need an egr that was designed for less backpressure. I was told that a '96 Z28 stick egr valve will cure it. I know for sure that it fits and is a direct swap. However, havent gotten the chance to get one yet. I plan too once i get paid :P
hectre13
Dec 11, 2023 08:14 AM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mizz0313
Aug 12, 2015 06:45 AM
92purpz28
Aug 11, 2015 02:30 PM
