Need help with my brakes! Stat!
Old Feb 11, 2001 | 06:19 PM
rusty Z's Avatar
I'm taking off my rear axle to swap with another. It's a drum to drum swap so that's the easy part. The problem is I have taken off every nut and bolt except for the brakelines. I cannot disconnect the E-cables or the main brake line. I don't know if the parts are too rusted or I'm approaching it wrong. Can either of these be disconnected without screwing up the parts? These are the last two things holding the axle on, HELP! Thanks.
'85 Z28 Copper/ Gold, LG4
dual snorkel w/ ram air, Accel Cap Rotor and 8MM wires, Edelbrock Headers, Catco Cat, Flowmaster 80 series
American Racing Wheels. 350 crate in the future.
Old Feb 11, 2001 | 06:42 PM
ede's Avatar
ede
i usually just unbolt the backing plates from the axle tubes, then you don't have to mes with brake lines or e brakes.
ICON Motorsports
1st & 3rd
Old Feb 12, 2001 | 08:24 PM
Eggplant Jeff's Avatar
Lots of WD-40, wait a bit, lots more WD-40... then try. It should help penetrate the rust. I don't know about the e-brake cables (never disconnected mine) but the brake hoses should give after some lubricating. Make sure you're turning them the correct direction (I'm not kidding, I've done that a few times... "WHY WON'T THIS COME OFF???? Oh...").
MSRed91Camaro
Oct 6, 2015 01:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
