Spark Plugs
Old Mar 1, 2004 | 05:48 PM
Fastcam's Avatar
Car: 1986 Z28
Engine: 305 LG4
Transmission: 700 R4
Spark Plugs
Ok i was trying to change my spark plugs in my 1986 z28 305 today and all i have to say is how the **** do u do it?? I was useing exstantions and swivals and i couldn't get to all of the ones in the back.. How do u do it is ther a specil techniqie or tool??? Thanks..
Old Mar 1, 2004 | 06:23 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Well the plugs are 5/8" so you'd obviously need a deep 5/8" spark plug socket, and possibly a 5/8" combination wrench. If you can't get the spark plug socket in there, try using the socket directly on the spark plug without the ratchet, and then turn the socket with a 14mm wrench. If that's not working for you, try putting the 5/8" wrench on it.
As painful as it sounds, they come out so much easier when the engine is warm. Don't forget the penetrating fluid for old nasty plugs.
Old Mar 1, 2004 | 06:27 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
With the stock exhaust manifolds you should be able to get most of them from the top and rearward ones from underneith. When you go to headers it may be time to modify one of your sockets or buy one like I did from ebay. This tool makes things so much easier and I can install and or remove plugs in a few minutes.
Old Mar 1, 2004 | 06:50 PM
RJR99SS's Avatar
I've always found its easiest just to do them all from underneath the car.
Old Mar 2, 2004 | 05:46 AM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
The easiest and cheapest way to get them is to use a double ended ring spanner. Most spanners have an open end and a ring end, but you can get them with a ring at both ends, and these ones usually have the ring part ofset by 2".
I found that with the headers in the way, these ring spanners work a treat. You have to be careful to get a good alignment onto the nut part of the plug and don't hit the ceramic part.
Si.
Old Mar 2, 2004 | 10:26 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
listen to the scotsman. for those of you who speak American and not ENGLISH, a ring-type spanner is a box end wrench.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
