How much HP is this gonna give me?
Old Mar 1, 2004 | 08:51 PM
razz's Avatar
Car: 1994 Firebird
Engine: V6 3.4L
this is what i just installed through the winter in my garage.
it was plain stock before.
-I removed the cat converter.
-Installed hedmen hedders (with Y-pipe)
-flow master muffler 80 series 2.5 inch IN/OUT.
-600cfm edelbrock carb.
-Edelbrock performer intake.
How much more HP should that give me??!!
Old Mar 1, 2004 | 08:53 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Nothing to something! What engine do you have?
Old Mar 1, 2004 | 08:54 PM
razz's Avatar
Car: 1994 Firebird
Engine: V6 3.4L
V8 5.0L 305
Old Mar 1, 2004 | 09:56 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Take it to the dyno. All your power questions shall be answered.
Old Mar 1, 2004 | 10:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Was it a 120 HP 305 2-barrel long block? was it a 190 HP L69? was it a TBI 305? You'll get vastly different results depending on what you started with.
Old Mar 1, 2004 | 10:30 PM
razz's Avatar
Car: 1994 Firebird
Engine: V6 3.4L
it was a 4bbl 305. stock was 150hp or 170hp, i'm not sure, i'm getting different answers. I guess i should bring it to a dyno... but that cost money . But yeah, i'll go do that when i take it out of storage (2-3weeks).
thanks guys
Old Mar 1, 2004 | 10:35 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
So it's almost certainly the LG4 base-model 4-barrel.
Out of the list of thing you listed, the one and only thing that actually gave you more power, was the headers. And without a new cam, that gave you at most 20 HP.
One of those mods, the carb, set you back in the power dept. if you didn't also change the distributor. So that one could be a net HP loss rather than a gain.
So overall I'd guess you're somewhere a little shy of 200 HP.
We can guess all day long. We might even actually be right. Or we might be totally off base. The only way you're really going to know the truth, is to take it to the dyno.
A car with 200 crank HP will put about 155-160 to the rear wheels. That's what I'd expect you'll see at most on the dyno.
92projectcamaro
Dec 8, 2015 12:25 AM
91 SrS
Oct 7, 2015 04:32 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Vincent135
Sep 28, 2015 10:50 PM
