How important are...
Old Mar 2, 2004 | 02:06 AM
BadBlue91RS's Avatar
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
Rear brakes? Whats the percentage of the actual stopping that they do?
I'm having ONE HELL OF A TIME replacing the line that runs from the master cyl. to the rubber line with the "T" on the end. It's a different size line than the rest of the lines (bigger than 3/16 and smaller than 1/4) and NOBODY carries the line!
So, for a temporary fix, I intend to just go without the rear brakes for now. Or would that be too dangerous?
Thanks in advance!
Old Mar 2, 2004 | 02:27 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
the line is 10 mm, double flare.
Old Mar 2, 2004 | 02:30 AM
Engine: 383, L69
I had to use a series of adapters to use 1/4 line, i used a metric flare to 3/16 double flare, then that to a 1/4 doulble flare then used 1/4 line.
edit: I also got all of this at car quest.
Old Mar 2, 2004 | 05:13 AM
ede's Avatar
ede
i'd rate brakes front or rear as important as a steering wheel. you'd be opening yourself up for all kinds of liabiliy if you were in a crash and at fault.
Old Mar 2, 2004 | 05:41 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I have heard something like 75% front, 25% rear, as far as stopping power. In other words, the front brakes are doing 75% of the work. Dont quote me on those numbers though, I have no research whatsoever to show that. However, front brake pads do wear out faster.
Driving without the rear brakes is a big no-no though. Its not so much that they need to help stop the car, but they DO need to help stop the rear wheels from turning during braking. Lets say you drive with no rear brakes. It would probably be okay just crusing around, even though you would definitely notice a big loss in stopping power. However, if you had to slam on the brakes hard, the front tires would lock, or come close to locking, yet the rear wheels, as well as the entire rotating weight of the driveline is still spinnng, and isnt bening slowed at all. You would most likely spin 180 degrees around, if not completely off the road. Cars have brakes on all fours for a reason.
Old Mar 2, 2004 | 09:46 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Its not to hard to drive a car without rear brakes. Your car isnt going to instantly spin. The engine and trans will actually help slow the rear wheels not make them go faster(unless your dumb and you have both pedals to the floor). On the bright side you have a temporary line loc so might as well go out and use it.
If you want hard to drive try driving a diagnally split system that loses half the system and has one of the working corners so worn it doesnt brake at all.
Old Mar 2, 2004 | 02:51 PM
mattscamaro's Avatar
you dont need back brakes, but why not keep them. its one of those things you dont want to fix but it would be stupid not to
Old Mar 2, 2004 | 03:08 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Old Mar 2, 2004 | 05:20 PM
MurCurY's Avatar
Car: 86 Camaro Berlinetta
i did the same thing on my monte carlo...went to have it inspected with all the adapters to make things fit...it failed. Can't use compression fittings on brake lines is what the guy said.
Old Mar 2, 2004 | 10:29 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
MurCury....your not supposed to...says so on the compression fitting package BUT I work at advance and almost everyone who does brake work uses them. But we get some shady people in there so who knows.
Old Mar 3, 2004 | 05:28 AM
Car: 1991 Camaro RS
Well, I'm going to go back to advanced auto today and try to locate the one fitting I'm missing. If I can find it, I'll have rear brakes again. If not...no rear brakes for a while.
I figure if I downshift the tranny and keep my distance in traffic I'll be ok. Wish me luck finding the last fitting!
Old Mar 5, 2004 | 11:26 AM
Transmission: 4l60e
Just make sure you ask the older looking "I've been working here for 10 years" parts guy at advance. Usually the most knowledgable guys are older and NOT managers. Most of the managers don't know much.
What fitting do you need exactly?
ZZ3Astro
Aug 13, 2019 12:57 AM
Jorlain
Oct 8, 2015 01:57 AM
gta892000
Sep 16, 2015 12:37 AM
Ozz1967
Aug 16, 2015 10:23 PM
