Broken grade 8 bolt in crankshaft
Old Feb 13, 2001 | 06:29 PM
BenDoe's Avatar
So there I was, pulling the harmonic dampner on with the bolt that holds on the dampner and pully to the crankshaft.... and all of the sudden... snap... i broke the bolt. Its recessed into the crankshaft about a centimeter... does anybody out there have any how to articles or info on how to remove broken grade 8 bolts?
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218 the usual street racer with a stock chip.
Gained 20HP by porting and polishing my EGR passage.
Cars beaten as of 01/01/01
95 Acura Legend
Lost to as of 01/01/01
Old Feb 13, 2001 | 06:35 PM
ede's Avatar
ede
they make tools for pressing the damper onto the cranks. i'd take the crank to a machine shop and let them do it. i had 2 broke bolts removed from flywheel flange for 20 dollars. if you're set on removing the bolt, you could try a punch and hammer and see if it'll turn out ,it may not be tight. drill it and use an easy out, but i don't like them. weld a nut on the broke bolt and wrench it out, but being the crank you'd have to be very careful.
ICON Motorsports
1st & 3rd
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
