Have casting # what TUned port injection do i have?? Help!!
Old Feb 13, 2001 | 04:28 PM
vortech305's Avatar
I bought a 305 TPI from a firebird and it had five speed. But i dont know what tuned p0rt i have i do have the casting nuber its 14093627. Please help i need to know exactly what year it is i know its either 87' to 92' it has roller cam. Dont have harness so need to know what i have mass air flow or speed density. What year is this tuned port thanks oh yeah on the left side of the block it also has a number its G148. thanks
Old Feb 13, 2001 | 04:32 PM
vortech305's Avatar
i know what the mass air flow looks like and the speed density i just wanna know what year the motor is i also know its a 305 TPI thanks.
Old Feb 13, 2001 | 05:30 PM
jms's Avatar
jms
Most of the time, the casting date G148 would mean the part was cast on July (letter G is the 7th month) 14, 1988. Sometimes you have to decide if the 8 would be 1958, '68, '78, '88, or '98. However in your situation, the clues you give mean it is most likely 1988. With a casting date this late in the model year (remember-the new cars usually came out in August or September and a casting date is usually a few weeks to a couple of months ahead of the car's actual build date), in all likelyhood, your engine is from a 1989 model.
jms
Old Feb 13, 2001 | 06:28 PM
vortech305's Avatar
U know what im an idiot i forget to write down that i had the motor rebuild and there was a crack in the block and the machinest asked if i wanted a new block so i said yeah and I just want to make sure if he jipped me or not the casting number i gave u was from the new block that he installed(hopefully) i dont think its an 89 because the back on the computer the code says from 87 to 88 i know its sounds stupid but is there a difference between an 87 and 88 and if so what r they.
Once again i apologize.
thank u
Old Feb 13, 2001 | 06:53 PM
jms's Avatar
jms
As long as it is a roller cam block, there should be very little difference. Once again, the casting number says it was made in 1988 but most likely came out in an '89 vehicle.
jms
customblackbird
Oct 1, 2015 04:30 PM
mrestrictrplate
Sep 21, 2015 11:24 AM
eustodp
Sep 20, 2015 05:09 PM
355tpipickup
Sep 13, 2015 11:35 PM
m00n420
Sep 11, 2015 02:39 PM
