305 Heads
Old Mar 3, 2004 | 09:47 PM
brent4a's Avatar
Car: 90 Formula
Engine: 305 tpi
305 Heads
Any ideas for a fairly easy to get set of heads for a moderate performance 305 ? I am looking for ones that bolt up w/o alot of work needed.......Thanks for any opinions
Old Mar 3, 2004 | 10:25 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Check the classified board. Usually some on there every now and then.
If your looking for them to just bolt on then you will want 081 castings if you have an 87-92. Pre-87 engine and you will want 416 casting. Do not get the 187 casting, those are the swirl port heads (LO3).
Old Mar 3, 2004 | 10:41 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
if you want, I know a good buddy selling his GM performance bowtie heads. already ported, polished, oversized manley valves, hot tanked, magnafluxed, and painted black. hardened seats, good springs, the springs can handle up to .600" inches of lift. let me know if you're interested. it comes with the valves and springs. just needs rockers.
Old Mar 3, 2004 | 11:39 PM
brent4a's Avatar
Car: 90 Formula
Engine: 305 tpi
Dumb question , but what do I have to modify on 350 heads to fit onto a 305 block ? I also want to keep the TPI
Old Mar 3, 2004 | 11:49 PM
87Formula4bbl's Avatar
Car: '87 Formula
They do not need modified to fit a 305 block, but you will more than likely you will lose compression. Actually, you will if your going from 58cc to a higher volume chamber size, such as 64cc heads.
Keeping TPI is not a problem here.
Old Mar 4, 2004 | 12:55 AM
brent4a's Avatar
Car: 90 Formula
Engine: 305 tpi
Not trying to be a pain, my car is in another state,but what are the usual heads on my car ? What cc size ? ...Thanks
Old Mar 4, 2004 | 07:34 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The heads on your car are the garbage 187's and have 58cc chambers.
Old Mar 4, 2004 | 07:45 AM
smithtc's Avatar
1990 formula 5.0 "F" engine will have the 081 heads. Not the swirl port heads everyone is afraid of. The 081 heads respond well to a mild port job. Thye are 58cc combustion chamber. 1.84" intake valves, 1.50" exhaust valves
Old Mar 4, 2004 | 08:45 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Yeah, his sig says he has a 305 TPI, so his heads are the 081s ready for a good port and polish.
Follow the link at the end of my sig.
Old Mar 4, 2004 | 10:34 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I geuss it pays to read the fine print. Yea your stock heads are fine and I would just port them. They can become real good performers with some port work.
Old Mar 4, 2004 | 01:44 PM
stupid4901's Avatar
Can you run heads with 2.02 intake and 1.5 exhaust on a 305?
Old Mar 4, 2004 | 01:52 PM
Car: '87 Formula
From reading other posts, I think that 2.02 is too large, you will have clearance problems with them. Even if you could run them, I think there's no need to go that large.
Old Mar 4, 2004 | 02:05 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
This is correct. Even if you did have proper clearance they would not be benficial because the valve will shroud incomming air from the side that is closest to the cylinder wall. A 1.94 intake valve will make more power.
Old Mar 6, 2004 | 07:38 PM
Fast305's Avatar
Car: 1983 G20 Van
Engine: 305 4bbl
Transmission: Possesed 700r4
A racing style 1.84 will even make more than 1.94 in the horsepower race.
Old Mar 6, 2004 | 08:03 PM
smithtc's Avatar
huh?
Are you talking in terms of a 305 cubic inch motor?
Guys on this board have gotten 220cfm flow at 28" and 0.5000" lift for intake using 1.84 inch valves which is plenty of flow for a 305 yes...but can you provide some proof of your blanket statement or explain???
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
