Oil pump HELP
Old Feb 14, 2001 | 07:25 PM
92blkcamarors305TBI's Avatar
Oil pump HELP
I recently had motor work done to my car, a new comp cam and valve train. A new oil filter and new oil was put in it, but now my oil pressure is running lower than ever before. its not in the red yet but at idle it gets real close and also only when it idles it starts making a rubbing sound at the timing chain cover like its starving for oil. but when i push up the rpms a little the sound goes away. WHATS WRONG WHAT CAN I DO PLEASE HELP.
PS the car runs great its more powerful than ever since i had the work done. its just the oil pressure problem that has me really worried.
Old Feb 14, 2001 | 07:52 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Before getting excited about the pump, check the oil pressure some other way. Or, just replace the sending unit, they go bad very often.
The sound could be any number of things... get a piece of heater haose and stick one end in your ear and listen all around to pinpoint the exact source of the noise.
ICON Motorsports
Old Feb 14, 2001 | 07:58 PM
kevinc's Avatar
Car: 1982 Z28
If you had it done, I'd recommend you take it back to the shop and have them look at it.
If you start tinkering you'll void any warranty they might have in effect.
-Kevin
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
