Tips on sealing a one piece oil pan gasket
Old Feb 14, 2001 | 07:22 PM
KeithA's Avatar
I changed my one piece oil pan gasket and it still weeps in the rear. They claim the new ones are fool proof but I guess they didn't count on someone like me actually working on a car. I put small dabs of silicone in the corners but that didn't seem to make a difference. Any suggestions from a GM tech would be appreciated. How do you ensure that new gasket you put on a paying customers car doesn't leak?
They say the third time is the charm.
Old Feb 14, 2001 | 07:52 PM
Kyle87Z28's Avatar
I work for a GM dealer, just make sure the pan and block are really clean and I usually run a bead of *** 'y adhesive on top and bottom of the gasket. The *** 'y adhesive is great, the pn is 12346141, get it from a dealer, it's about $9.00 a tube. Good LUck.
Old Feb 15, 2001 | 12:01 PM
KeithA's Avatar
Thank you Kyle, I was trying to avoid using the "goop" route but that sounds like the most dependable way to go.
Old Feb 15, 2001 | 12:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Hey Kyle don't forget to use that *** 'y sealer when you're installing a pet**** in your radiator!
This program censors the oddest things. I tried to talk once about getting a bearing race ****ed in its bore, and it washed my mouth out with soap on that one too.
ICON Motorsports
MoJoe
Sep 24, 2015 09:12 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
MY87LT
Aug 17, 2015 08:43 AM
