Decking block after re-sleeve?
Old Mar 5, 2004 | 03:49 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Does an aluminium block need decking after a re-sleeve.The block was originally decked but it has new liners.Would the re-sleeving cause some distortion or the new sleeves not be level with the top of the block to need decking.Is there any way to check this without taking it to a machine shop,if so what tools are we looking at.
Thanks Neil.
Old Mar 6, 2004 | 05:17 AM
ede's Avatar
ede
you can check the flatness with a precission straight edge and feeler gage, around .005 would be the max. if you don't have a precission straight edge you may have a hard time checking it. i've used the machined surface of a level before but i checked it with a straight edge so i knew what it was out.
Old Mar 6, 2004 | 08:04 AM
Vader's Avatar
Your other options would be a surface plate and prussian blue dye, a CMM, or a laser surface profiler.
Personally, I would think that any time a block is sleeved, the potential for distortion would be great, so checking for deck and bore squareness would be a must-do item.
Old Mar 6, 2004 | 08:49 AM
Car: '92 RS Camaro
Transmission: TH400
Thanks for your input chaps.A good friend of mine is an engineer,and I could lay my hands on a precision straight edge.As for checking the bores are round,I presume a good pair of verniers would be OK?
Old Mar 6, 2004 | 05:32 PM
Vader's Avatar
You may jest, but a set of telescope gauges and a good quality vernier caliper in the hands of the right operator as just as accurate as a bore gauge or inside micrometer. I generally use an inside mic, then check my work with a telescope gauge and mic or caliper (dial caliper, though). My only larger mics are trash - genuine Japanium (less than Mitutoyo), but the inside, gauges, and calipers/smaller mics are all Starrett stuff that I'd rely on.
Old Mar 6, 2004 | 05:37 PM
ede's Avatar
ede
i use a dial bore gauge and double check myself with a telescope gauge and mic on the holes.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sheachopper
Jul 31, 2019 11:27 AM
skinny z
Oct 5, 2015 06:23 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
