300hp 305 TPI Cooling problems!! HELP!!!!!!!!!!
Old Feb 11, 2001 | 06:00 PM
vortech305's Avatar
I Have a 305 tpi with a t-5 manual tranny. The 305 TPI was from an 88' firebird and im putting it in my 92' camaro RS which has a 3.1 automatic. Can i reuse my 3.1 radiator, it seems in good condition. I also got help from one guy and he told me to get a dual fan set up,should i and if so what type and size to i need. I also have a 180 degree thermostat, and a flow kooler(flows 30% over stock water pump) is this ok. What can i possible do besides spening $480.00 on be cool radiator is there a place that sells an alluminum radiator for a cheap price. thanks
Old Feb 11, 2001 | 06:21 PM
The ODB's Avatar
<font face="Verdana, Arial" size="2">Originally posted by vortech305:
</font>
Griffin will make you an aluminum radiator for much cheaper, but your stock V6 radiator should be more than enough already.
There are reasons why GM went to the dual-fan setup, but the older 85-86 single fans cool much better. Just grab one from a junkyard and wire it using a heavyduty relay.
ODB
Old Feb 12, 2001 | 12:23 AM
burnoutrpm's Avatar
im with odb the dual fan setup is good but, think about the drain on the alt and batt!? its twice that of the single fan! a single should be good enough! the stock 3.1 rad. could be big enoughbut, if its the one used in the f-body v8s then no way to small id also go with either the griffin or get a universal 31x19 be coolrad. for about 250$ much cheaper than the correct one for those cars!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 160 (882) heads,.447/.447 lift 222@.050 duration speed pro 327/350hp cam 350 .40 over (356) Edlebrock torker2 and a 600 edlebrock manual choke (1405)
Future mods performer rpm air gap intake (polished) comp roller cam, and way better headsa 400 defintely in the works!
Old Feb 12, 2001 | 12:59 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Definitely use a good water pump and single or dual electrics. I'd get the cheapest radiator you can find that has 6 or 7 tubes - check in summit they have progressively more tubes based on your horsepower - if your v-6 one has enough by that standard just get it flushed and use all new hoses with good coolant and water wetter and you should be fine.
Base: 89 Iroc-Z LB9 auto 2.73 posi
Exh: 3" Dynomax muffler, 3" Pipe in place of cat
Ign: GMPP 8MM wires, Accel cap&rotor, AC Plugs
Fuel: Cleaned and flow-matched injectors, afpr, !air pump&diverter valve
Sound: Clarion deck, Kicker speakers and amps
Suspension/Drivetrain: KYB Shocks, BMR Strut Tower Brace
Misc: TB Bypass, All synthetics, Flexlite Transmission cooler
On the way: flow tech headers, alum. driveshaft
"You say turn that volume down? Well all I gotta say to you is NO, no no no no...
I want to Rock - ROCK - I want to Rock - ROCK - I want to Rock with you..."
Old Feb 12, 2001 | 02:06 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Griffen makes a radiator specifically for third gens. It's rated for engines up to 450 Horsepower.
Griffen part number:6-282AE-BAX
It sells for between three and four hundred. I got it for $310 about a year ago.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
Old Feb 15, 2001 | 03:29 PM
vortech305's Avatar
thanks guys i appreciate all your help thanks.
Old Feb 15, 2001 | 05:23 PM
Tallboy's Avatar
if u havent already done so get a LOWER TEMP thermostat(180) and fan switch or do it manually
if u do have a lower stat...try drilling 2 1/16 holes in the side of the thermo for continous cooling(around the rim)
and a better water pump
no I dont overheat
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
