Pro action Vortecs Vs. GM vortecs???
Old Mar 7, 2004 | 08:19 AM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
WHich one of these heads are better cause they are the same price I just wonder if there are any differences. Do they have different springs for higher lifts???? I have no clue about either of them I just know i want a set of vortecs.
Old Mar 7, 2004 | 01:11 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Well lets put it this way the Pro heads are performance and the GM heads are stock truck heads. Which would be better the Pro heads.
They are a much better casting, already have screw-in studs, and can take bigger springs and more lift without machining. Its not even a question what i would use.
Why ever run any stock parts when new aftermarket performance parts are the same price!!!!?
Old Mar 7, 2004 | 02:04 PM
Car: 89 camaro RS
hey thanks man
Old Mar 7, 2004 | 03:37 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I'll never believe the Pro Toplines flow as well as Vortec heads until I see actual flow charts on the same flow bench, and HP results from both heads on the same engine on the same dyno.
Not saying the Vortecs are the head of all heads, but they're a damn good design. To simply mimic Vortecs and put in "performance" accesories does not make them better.
Just like I'll never believe their intakes flow as well, or make as much power as the Edelbrock intakes they mimic.
Old Mar 8, 2004 | 11:19 AM
Car: 89 camaro RS
ALright now I am really confused about what to get.
Old Mar 8, 2004 | 11:40 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Basically, is what he is trying to say is you should try to aquire a flow sheet for the Pro Action heads. Once you do that, compare stock flow with the Pro Action flow and work from there.
Old Mar 8, 2004 | 12:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It would be nice if someone had such flow sheets. If they flow as well as factory heads, they're a better deal than trying to upgrade factory heads with springs, studs, etc.
Old Mar 8, 2004 | 09:48 PM
wallyZ/28's Avatar
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
pace performance parts has a set of vortech heads beefed up by wheeler motorsports around 300 a headand pace has some with screw in studs and gm guideplates already installed for around 400
Old Mar 9, 2004 | 12:21 AM
Car: 89 camaro RS
DOes anyone have any flow data for the GM vortec heads???
Old Mar 9, 2004 | 01:35 AM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Transmission: TH350 3000stall
Flow chart
Here this is from:http://www.chevyhiperformance.com/techarticles/41598/
Old Mar 9, 2004 | 12:35 PM
Car: 89 camaro RS
Hey smoktire,
How much horsepower is that engine setup you have..I am shooting for the exact same thing with mine.
Old Mar 9, 2004 | 01:58 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
For the 191 heads setup using www.virtualengine2000.com with my car weight with me (3785lbs) and my best dragstrip time 14.01@99mph it give me about 344 flywheel HP
For the vortec setup that is verry similar to this one found at:http://www.superchevy-web.com/tech/0...m15/index.html
T15--DM Part 6: GM Vortec iron heads SDPC PN SD8060A (64cc chambers, 170cc intake runner volume, 1.94/1.50 valves) with Comp Cams 1.6:1 Magnum roller tip rockers PN 1418-16, Edelbrock Performer RPM Air Gap Vortec intake manifold PN 7516 COMP Cams XE262H cam (262/270 advance duration, 218/224 duration at .050, .462/.469 valve lift, 110 lobe separation) straight up. That give 416HP 440TQ. Using www.virtualengine2000.com 416 hp should push my car to a :hail: 12.78@105mph +\- without nitrous
Old Mar 9, 2004 | 02:04 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
This is my page with the vortec stuff...
http://www.cardomain.com/memberpage/194306/3
Old Mar 9, 2004 | 03:21 PM
Car: 89 camaro RS
i was thinking about using this setup....Vortec heads with 10.2:1 compression, comp cams 274* extreme energy flat tappet cam, Comp cams 1.6 roller tip rockers, Edelbrock RPM vortec intake, Holley 650double pumper carb...I have heard this is a good setup but I dont know how it runs HP wise and Torque wise.
Old Mar 22, 2004 | 09:41 AM
Car: 89 camaro RS
can anyone run that on a desktop dyno for me
Old Mar 22, 2004 | 11:55 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
In that flow chart it ways "Vortec 885" ...what the heck are 885's? The only vortecs I've ever seen are 062, 906, and those other castings they put on 305's (I forget the casting #)
Old Mar 22, 2004 | 12:08 PM
AJ_92RS's Avatar
That's the old part # suffix.
They've changed part numbers since then.
Old Mar 22, 2004 | 12:43 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Car Craft
Car Craft p.64 september 2002 issue.
They use a .060 over 350 =358 with flat top 4 valve relief near 10.1:1cr with Scoggin-Dickeys vortec that can support .550 lift-Comp cams XE274 with 1.6: full roller rocker-Edelbrock 750 carb -stock HEI -1.750 headers 3 inches pipes with mufflers-Air gap intake with 1 inch carb spacer and they got 442HP@5900-452lb-ft@4400
Old Mar 23, 2004 | 10:03 AM
Car: 89 camaro RS
awesome to hear
Old Mar 24, 2004 | 10:30 AM
Homer's Avatar
Car: 1991 RS
Engine: 305 TBI
Re: Pro action Vortecs Vs. GM vortecs???
Originally posted by supermaxxbasher
... they are the same price ...
Where did you find these for the same price? How much?
Old Mar 24, 2004 | 11:40 AM
Car: 89 camaro RS
http://www.primediapowerpages.com/cg...0216&2D1007246 this is the site that has them for $500 a set
F.I. 57 Belair
Aug 23, 2021 01:09 AM
tmellott89
Oct 14, 2015 02:06 PM
djmarch
Oct 2, 2015 10:41 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
