light of check engineness
Old Mar 24, 2004 | 04:15 AM
Slim89BlueRS's Avatar
well its telling me...
so i understand that with the 2.8 litre its only the emission system that would cause the light to light up, so how do i find out whats going on its an 89 by the way
without paying for it
Old Mar 24, 2004 | 04:39 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Check for codes. If you don't know how, look at the tech articles. Let us know what code you are getting.
Old Mar 24, 2004 | 05:01 AM
well i checked it out and i dont really understand the tech article
so i wire pin 6 to pin 12
and then turn the ignition to on, without starting my car
a "12" code will appear, which just tells me what??
and then after that code, the problem codes will appear?
so i simply record these and tell you guys, then you fix my probelm???
thanks dooders
Old Mar 24, 2004 | 07:44 AM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
thanks dooders
Code 12 basically means the ignition is on but the engine is off, because it's detected a lack of vacuum. Every car should display this code.
Code 12 will flash 3 times, followed by any codes stored in the ECM, again 3 times for each, and then it'll revert back to code 12 again and repeat until you remove the jumper.
List any codes after the code 12 and we'll be able to translate them for you.
Old Mar 24, 2004 | 12:11 PM
Vader's Avatar
Far more than just the emission control system will set a light, unless you consider running the engine, shifting the transmission, running the fuel pump, etc. as part of "emission control".
You can also download this sheet and decode the errors you read: GM OBD Error Codes.pdf
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
