tampering with wiper motor module!!
Old Mar 7, 2004 | 03:28 PM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
I took the cover off of the wiper motor module and I was trying to fix it because my DELAY wipers dont work, but everything else works on the switch. . .So when I decided to take the cover off and to look at it. . .I put the cover back on and my wipers dont move at all. . .How do I fix this?? How is the mechanical arm suppose to be set??
Old Mar 7, 2004 | 11:54 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You probably have the drive pin in the wrong location. Check this picture out.
Old Mar 9, 2004 | 09:14 AM
warrior_91's Avatar
Car: 86 T/A
Thank You very much TRICKSTER! That diagram helped alot! I got it back to where it was. . . .but still. . .Cant figure out why my DELAY option dont work??
Old Mar 9, 2004 | 09:30 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Did you do the delay resistance test that was in the information that I sent you and you're welcome for the diagram.
Old Apr 28, 2008 | 04:15 PM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
Re: tampering with wiper motor module!!
Hi,
I have the same problem for my 85 TA and would appreciate info on how to do that resistance test before buying a new motor assembly....
Frozer!!!
Jan 19, 2024 04:55 PM
Bryan F
Aug 27, 2015 07:28 AM
Randomtask2
Aug 26, 2015 03:34 PM
crazynights
Aug 21, 2015 06:53 AM
slade5612
Aug 11, 2015 07:19 PM
