Tricky Dicky Switchy
Old Feb 16, 2001 | 02:42 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Well, congruent with my newfound obsession to make as many things in my car switchable as possible, I wanted to see if anyone on here has tried a switch to simultaneously disable the O2 sensor on tpi and also switch the cts of the computer to 640 ohms while switching the fan cts to the hottest setting. Oh, and this would also be with about 55-60 psi. Wouldn't the effect when the switch was thrown be tremendous? Bad mileage sure but that's why the switch. I had fun torching a new mercedes on the highway today but with a switch like that and once I install my normally closed 3-4 trans switch it would have been even more convincing. The computer would not see O2 data so the increased pressure would have a real effect to the tune of maybe 20-25 horses. It would also see a cold engine so pulse width would be increased compounding the pressure effect. The fans would come on for some real cooling and I'm thinking the engine would scream. Oh, and speaking of rpms, with a stroke of 3.48 on a stock LB9 isn't my max rpm something like 6034? It just seems odd that my redline is 5 grand if the "real" redline is 1K more. Thanks for info.
Base: 89 Iroc-Z LB9 auto 2.73 posi
Exh: 3" Dynomax muffler, 3" Pipe in place of cat
Ign: GMPP 8MM wires, Accel cap&rotor, AC Plugs
Fuel: Cleaned and flow-matched injectors, afpr, !air pump&diverter valve
Sound: Clarion deck, Kicker speakers and amps
Suspension/Drivetrain: KYB Shocks, BMR Strut Tower Brace
Misc: TB Bypass, All synthetics, Flexlite Transmission cooler
On the way: flow tech headers, alum. driveshaft
"You say turn that volume down? Well all I gotta say to you is NO, no no no no...
I want to Rock - ROCK - I want to Rock - ROCK - I want to Rock with you..."
Old Feb 16, 2001 | 11:24 AM
snakeskinner's Avatar
sounds more to me like the ecm would go into limp home mode and lose power.
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
73 bronco
Old Feb 16, 2001 | 05:51 PM
Blade's Avatar
Well when you go WOT, the computer already ignores the 02 sensor and goes into open loop. Disabling the 02 sensor won't make the ECM go into limp home, it will just run in open loop all the time. I don't know about 25hp, but fooling the computer into thinking it's running colder is gonna have a minimal effect on power.
92 Z28 5.7
Ported stock heads, XR270HR-10 cam, TES headers
Crane AFPR, Flowmaster catback, MSD ignition
#24 SVO injectors, 1LE aluminum driveshaft.
Best ET 13.3@107 mph
Click here to see my car at Truspeed.org
Check out Truspeed
Check out the Bin Archive
Old Feb 17, 2001 | 01:09 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Oh, I had just read in "how to tune and modify chevrolet fuel injection" that the reason boosting fp does NOT result in huge hp improvements is the O2 telling the computer to reduce pulse width. He suggests disconnecting the O2 at the track to counter this. Thanks for the opinions, I had wondered about limp home mode... Hey kYle how come you don't post much anymore? Just tired of repetition? Well, my *boss* at the pizza place where I work just bought a turbonetics 10 psi kit for his eclipse spyder that's supposed to result in 384 hp, but I'm almost sure that's not at the wheels. I was going to build up an engine but I'm having too much fun with the 305; if I can come by a *cheap* rebuilt turbo or two and an old set of manifolds or cheap headers (flowtech or walker) I might try to fab something up...guess it's time to talk to Andris. Thanks again...
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
fasteddi
Sep 10, 2015 09:32 AM
jamesbob02
Jul 16, 2003 11:29 PM
va454ss
Feb 25, 2003 06:51 PM
james_fearn
Aftermarket Product Review
Jul 20, 2001 06:46 AM
