Would anyone DCR/SCR of this combo?
Old Mar 9, 2004 | 07:19 PM
1993GMCPU's Avatar
Car: TBI CHEVY, TPI 5.0 HO
Engine: 5.7 FIRST hp SMALL BLOCK, BIG BLOCKS!
350-40 over using Fel Pro H345NP40 pistons, 76 cc Heads, Cam 12-402-4, 3.42 gears automatic.
Old Mar 9, 2004 | 07:23 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Tell me the cc's dish or dome on those pistons, your head gasket thickness, and bore, and seat to seat duration on that cam and I can figure it out for you w/ my DCR/SCR calculator.
Old Mar 9, 2004 | 07:46 PM
1993GMCPU's Avatar
Federal Mogul gave me this:
Bore Dia. 4.040
Compression Distance 1.560
Weight 552 grams
Dome Volume -5cc's
Dome shape Flat with 4 valve reliefs
Top Ring 5/64"
2nd ring 5/64"
Oil Ring 3/16
Pin Style Press
Bore Clearance .0010
Fel Pro 1094 gasket .015 with 76 cc heads shaved 20 thousandths. 40 quench I believe and just trying to get it running until I can get 400 crank/piston next year.
260-AH-14 Adv Duration 260-268
(Duration .050: 212-218 .050 Duration) Lift 444 Lift 444
Int: 20 BTDC 60 ABDC
Exh: 72 BBDC 16 ATDC
Old Mar 9, 2004 | 07:53 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Static Compression Ratio is coming up as 9.1681:1
Dynamic Compression Ratio is 7.60211:1
That is using what you have provided me. Seems about right for the 76 cc chambers.
Old Mar 9, 2004 | 08:14 PM
1993GMCPU's Avatar
Cool and got a set of roller tip rockers, 1.6 from a friend, thank you!
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
roysatikas
Sep 22, 2015 08:15 PM
z28guy134
Sep 1, 2015 11:50 PM
