Strange problem with 92 RS
Old Feb 17, 2001 | 08:15 PM
Blade's Avatar
This is a 3.1 V6 T-5 RS. The problem I believe is the injectors. It will barely idle, and if you give it any amount of gas the engine will immediately die, however if you take it reeeeeeeaaaly easy pushing the gas pedal the RPM will creep up but then die after 2000 RPM. I unplugged one of the fuses for the injector banks and now the car idles a lot better and you can actually give it a little bit of gas and it will rev. If I unplug the other fuse for the other injector bank, the car wont start at all.
So, I would think bank1 doesnt inject any fuel at all! What else could it be ?
Old Feb 18, 2001 | 11:31 AM
The ODB's Avatar
that sounds really strange.
I would check the TPS first thing.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
andy74
Sep 3, 2015 08:41 AM
IROCtometal
Sep 2, 2015 02:01 PM
