Injector Problems??? Help!
Old Mar 11, 2004 | 10:02 PM
fuzzdrummer311's Avatar
Car: 1992 Camaro RS
Engine: 3.1 L MPFI
Okay so the other day I changed my fuel filter. Haynes says to relieve fuel pressure by removing the fuel pump fuse, which is *supposed* to be near the battery, but of course wasn't. So i undid the two injector fuses and tried to start the car. the pump primed, but the car wouldn't start, just turn over. So I change the fuel filter and also the plugs, and to my surprise the engine just turns over but doesn't start.
I've got 45 lbs of pressure to the fuel rail (tpi), i've got spark, and i know the filter is in the right way. I'm guessing the problem is with the injectors or hopefully not the ECM. So far 3 good old boys and one GM mechanic are baffled. You fellas got any good ideas? I'd really appreciate it.
Old Mar 12, 2004 | 10:07 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Pulling the injector fuses wont relieve fuel pressure. In the future just unplug the oil pressure switch or the fuel pump relay. Do you have power at the fuse panel for the injectors? How bout at the injectors? If the key was in the on position when you pulled the injector fuses you might have fried the cpu but that doesnt usually show up imediatly.
bryan623
Mar 22, 2021 06:43 PM
Street Lethal
Apr 30, 2019 12:14 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
tmellott89
Aug 16, 2015 02:58 PM
