The best oil for a new engine?
Old Mar 12, 2004 | 12:35 PM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
I just had my motor rebuilt and I'm curious what you guys think is the best oil? I have been thinking about running synthetic in it, but I don't really know that much about it. Also, can you run synthetic if it has had regular oil in it? Help me out!
Old Mar 12, 2004 | 12:48 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I would not run synthetic oil until at least the rings are broken in. Wait until about 5000 miles or so & switch to syn.
Old Mar 12, 2004 | 12:57 PM
87kevroc's Avatar
Car: 1987 Chevrolet Camaro Z28 IROC-Z
Transmission: TeamTripp Performance
IIRC when I had mine rebuilt, I put conventional 5w-30 and changed it after 1k, then 2 more changes, at 4k and 7k, then I switched to synthetic. My no. 1 cylinder burned oil, which the rebuilder attempted to fix but I lost patience with him. Got tired of paying $4/qt so I switched back to conventional after about 13k and have been running that way since. No. 1 cylinder still burns oil as evidenced by the spark plug.
The main issue that comes up when switching to synthetic is that it will tend to leak in high mileage engines, not a problem for you. I don't know of any reason not to switch to conventional from synthetic if you wanted to.
Old Mar 12, 2004 | 02:01 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
You can also mix the two. It not necessary to run one or the other. Just make sure you do the initial break in with the conventional.
Old Mar 12, 2004 | 02:41 PM
ede's Avatar
ede
30w dino oil , change again at 500 miles, then at 3000 i'd switch to synthetic
89GTAOz
May 16, 2020 09:31 AM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
