What is wrong with timing?
Old Mar 12, 2004 | 01:53 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
My car is running the ****s right now. I ckecked the timing and its at about 24*. Ok, so I'll adjust it. I disconnect the est wire and suprise! timing goes to 10* What do I do now?
Old Mar 12, 2004 | 01:57 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Your balancer might have slipped. That can be really hard to spot. Check the rubber and see if its moved. Sometimes balancers have marks that should line up but you can see theyve moved a little. Or you can just try moving you timing around till you get it to run how you want.
On the other hand it might not even be timing related. Some more info on how its running and why you think its timing would be helpfull.
Old Mar 12, 2004 | 02:54 PM
DaGoat's Avatar
Re: What is wrong with timing?
That's exactly what it should do. Sounds like it's time for a tuneup.
Check out the V6 section for TomP's tuneup.
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
evilstuie
Jan 9, 2020 08:29 PM
backtothe80s
Sep 5, 2015 12:39 AM
nuggie
Aug 25, 2015 01:27 PM
