antifreeze pissing outta engine
Old Mar 12, 2004 | 11:10 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
well guys i went to head to my gf's, i stopped to pick up gas, filled up, went to pay, and saw a bunch of anti freeze leaking from my car. i quickly popped the hood and saw it coming from the oil pan area (underneath of engine).
i haven't had a chance to look at it yet as its very dark and i have no ramps. anyone have any ideas on what it could be so i can stop worrying (or start)
Old Mar 12, 2004 | 11:50 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I hope it was just one of the drain plugs or heater hose leaking Dude. I seriously doubt that your oil pan is going to leak just anti-freeze. Good luck and hope for the best. Worst case is a cracked head or block. OUCH!!
Old Mar 13, 2004 | 12:07 AM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
it could also be the water pump leaking, or a blown head gasket... check to see where it's comming from in the light
Old Mar 13, 2004 | 12:10 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
well it did stop eventually stop, but alot of anti freeze came out and i managed to drive it home (about 5 kmh)
Old Mar 13, 2004 | 12:26 AM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
did you feel the car running any different? like more sluggish?
Old Mar 13, 2004 | 12:40 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
actually it felt like it was running a bit better, i didn;'t give it **** or anything i just drove it home like a granny
Old Mar 13, 2004 | 01:05 AM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
cuz if it felt sluggish, i'd say it was a head gasket or something because you'd be loosing compression. hmm... tell us what you find in the sunlight
Old Mar 13, 2004 | 01:14 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
will do
Old Mar 13, 2004 | 02:39 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
if there is a leak anywhere from or onto the engine its gonna drip down the oil pan.. so i'd say your problem is somewhere above the oil pan.
Old Mar 13, 2004 | 03:36 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
check the thermostat housing and see if there's any coolant comming from the water pump. if your not losing power i doubt you blew a headgasket, but that could still be a possibility. a good sign to see if it's the water pump is if your overheating. tell us what you find, we'll try our hardest to help
Old Mar 13, 2004 | 04:21 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
I bet on a water hose. The lower one.
Good luck.
Andy.
Old Mar 14, 2004 | 04:23 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
water pump gasket
took 3 hours to fix and its all better now
Andrew6.688
Dec 13, 2015 10:59 AM
Reddeath210
Oct 6, 2015 08:20 AM
djmarch
Aug 19, 2015 12:07 PM
legendaryhero7
Aug 12, 2015 06:19 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
