Cooling fancoming on at 110 degrees. Please help!!!
Old Feb 19, 2001 | 06:35 PM
jody92RS's Avatar
I have a 1992 camaro with a single cooling fan. I replaced the coolent temp sensor yesterday because the fan did not work at all and now the fan comes on at 110 degrees.
When I was tightning the sensor I heard something crack. Could I have ruined the new sensor? Also I had to replace the wiring to the sensor( original owner cut it). I wired one wire to the green and white wire and one directly to a ground on the car, Did I wire this up correctly? I believe that it now runs all the time. Please help!!!!!!!!!!
Thanks Jody
1992 25Th Anniversary Camaro
305 TBI
5 Speed
Old Feb 19, 2001 | 11:02 PM
Vader's Avatar
Jody,
Test the new CTS with an ohmmeter. The resistance should vary with coolant temperature.
The approximate values are as follows:
If your CTS isn't close to the resistances listed, you may have damaged it on installation.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Old Feb 19, 2001 | 11:05 PM
Vader's Avatar
Oops! I may have misread that one. You TBI car might have a fixed temperature sensor for the fan, in which case it would only turn on and off, not vary resistance. You still can check with an ohmmeter, but expect 0 ohms or infinity. It sounds as if you've got it wired correctly, but still may have damaged it on installation.
Later,
Vader
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
ndndndnd
Sep 28, 2015 08:00 AM
