stupid car is smoking....
Old Mar 14, 2004 | 07:28 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
im getting massive amounts of smoke when i come to a stop while downshifting, or when i have a heavy load accelerating up the cooper bridge.
it was dusk when i disovered this, so i donno if its "blue" or "black" or clutch.... theres 3 possibilitys:
1. new clutch... the clutch is slipping and putting up smoke... but.. i dont think this is it... i can rev with the clutch in, and no smoke, and it feels ok... in anycase, a LT4 clutch shouldnt slip behind a 152hp L03, no matter what.
2. im running rich when downshifting and on the "pump shot" for accelerating... im guessing this may be a good posiblity... i am running a automatic chip in the ECM (ANTT) and i just stuck the manual behind it... perhaps its nothing more then a tuning issue... i HOPE this is the case..
3. i blew the rings.... this is also possible.. athough i really really really hope its not. im just not ready to put the 400 in yet.
for all i know, the added stress of 6th gear with the 2.73s making the engine turn around 1300 RPM was enough stress (cyl pressure) to hurt it...
in anycase, i hope its not too bad... i hope its just the chip making it massivly rich.. (enough that i can see smoke in my rearview).. but somehow i think thats just wishful thinking
so, can running a auto chip on a car with a manual make the smoke happen or what? this is a L03 running ANTT
(btw, i JUST swapped in a T56 right before i saw this..... the car was a 700r4)
Old Mar 14, 2004 | 08:54 PM
Vader's Avatar
Another possibility is worn/leaking valve guides. They can tend to produce smoke on deceleration.
I suppose you don't have a wideband O² and a monitor to check the AFR while driving, eh? That would tell you a lot about your fuel calibrations.
I'd think you could cut the possibilities right in half if you could have someone follow you and determine if it is oil smoke or excess fuel smoke.
Old Mar 14, 2004 | 09:41 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
i cant believe i didnt think of that... i hope thats what it is... i have had the lil puff on startup for awhile.. about 3months now... athough there is no decel with the auto thats in it... im probly only seeing it now because of the manual....
i guess im changing valve seals this weekend
nope.... but then again, if it was so rich that it made smoke, then wouldnt it peg a narrowband O2 to rich? that would tell me somthing too right?
thats the plan for tomarrow.. or whenever i can meet a carguy friend.... no one besides my car friends would be able to tell the diff lol.....
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
