got a new motor need help
Old Mar 14, 2004 | 11:44 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
Got my new motor last night and its out of an 88 chevy truck. What I want to know is does anybody know if it is a 2 or 4 bolt - forged or cast crank - and roller or non roller I looked up the numbers but it could be either or on all the questions! As far as I know it was throttle body injected. Will the cam in it work on my TPI? O-yea its a 350. numbers are 14093638
Old Mar 15, 2004 | 04:50 AM
ede's Avatar
ede
WAG cast 4 bolt non roller yes the cam will work, how well is another question
Old Mar 15, 2004 | 08:32 AM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
will my heads and pushrods work?
Old Mar 15, 2004 | 09:08 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That would depend on what heads and push rods you have. In the case of the push rods, it will depend on whether they're for a roller cam or not, and whether you put a roller cam back into this other block.
A block is not inherently a 2-bolt block or a 4-bolt block; it's the same block, the factory just installed whichever main caps they thought appropriate. Trucks are likely to get 4-bolt caps.
Same for the roller cam; that casting has the provisions cast into it for the factory's roller weirdness, but they may or may not be finish machined, and it may or may not have the roller stuff in it even if the machine work is done. Most likely, being a truck, it's not machined.
Old Mar 16, 2004 | 02:42 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
It is a roller so will my heads work? The heads I want to use are my stock 350 TPI heads. Will I experience a toque or horsepower loss using the TBI truck cam instead of my TPI cam?
Old Mar 16, 2004 | 02:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Your heads will work.
Use the TPI cam. The TBI cam will cost you probably 20 HP, maybe more.
Old Mar 16, 2004 | 02:50 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
OOOO that hurts cuase my cam is all chewed up from not having the distributer tight enuf so I had a lot of cam knock in my old motor. Well actually I assume the cam is bad do you think I am right.
Old Mar 16, 2004 | 03:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Never heard of "cam knock" before...
I doubt the dist situation damaged the cam. I'd sure take it out and look at it before assuming it's bad.
If your L98 cam is in fact bad, get yourself a LT1 cam off of ebay or something. You can pick them up for $50 or so. Just make sure you get one out of a F or Y body, not a B body.
This is all assuming your block is machined for roller lifters, which I highly doubt. That's another thing to check and be certain of before buying anything, rather than assuming.
Old Mar 16, 2004 | 03:49 PM
86WS6_T/A's Avatar
Car: 2003 Mach 1
I wouldn't assume that block is a 4 bolt either. The motor in my car came out of a 1 ton 90 model Chevy pick-up. From what I was told it should have been a 4 bolt due to being in a 1 ton but it's just a plain jane 2 bolt non roller. I wouldn't assume anything. I'd pull the pan and intake to triple check.
Old Mar 16, 2004 | 09:02 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
Already checked while I was degreasing 4 bolt with roller lifters!
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
