cam selection
Old Feb 21, 2001 | 10:10 AM
406 S10 Man's Avatar
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
cam selection
What do you guys think about a Comp XE 274 in a 383? The heads will be stock LT-1 vette heads from '70 and the intake will be a Performer RPM. The comp ratio will be around 10:1 For those not familiar with the XE 274, it is a hydraulic flat tappet with 230/236 duration @ .050 and approximately .480/.487 lift. i think lsa is 110, but i don't remember. I know the heads suck, but we are dealing with limited resources right now, they could be changed to ironeagles later.
i have the XE 284 in my 406 and i love it, but i think it would be way too big in a smaller motor with stock heads.
any help would be appreciated.
88 S10
Dropped 3/4
18" Boyd Coddington Timeless 5s
Dart equipped 406
12.20 @ 115.25 mph
Old Feb 21, 2001 | 12:47 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I had that cam in my 400, it ran great. I'd say you should be happy with it. Run 1.6 rockers if possible; you'll have to up the spring size to 1.45" for that though.
ICON Motorsports
Old Feb 21, 2001 | 01:27 PM
Conv389drv's Avatar
I've heard of guys running a cam like that in a 350, which produces a lot of lope, but on a 383 it should be just right. (I think the 230 range duration is recommended)
Old Feb 21, 2001 | 03:50 PM
Polecat's Avatar
Perfect! I have the XE284 in my 383, but 3000 stall and 4.11 gears. It ought to pull great in your 383. And you are dead on. The Dart heads will be a prefect head setup for your 383 too.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Jorlain
Oct 8, 2015 01:57 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
customblackbird
Oct 1, 2015 04:30 PM
masonta
Sep 1, 2015 06:40 PM
