327 on a budget, how does this setup look?
Old Mar 17, 2004 | 11:37 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I have an old 327 short block out of a 67 camaro. The crank is a steel piece but it is spun pretty bad since the guy overrevved the motor and a connecting rod came loose. I disassembled the block and it looks ok and so does the crank, aside from a little machining. I was thining of getting the short block redone at my machine shop, crank turned, clean block,bore .030, new pistons, recondition rods, assembled. Then I want to throw on a set of L69 heads that I have collecting dust here in my shop. Heres the whole combo:
327 short block-> free
327 short block rebuild-> $500
L69 187 heads-> free
clean up the bowl area-> free
get heads redone-> $275
Rpm intake-> $125
600 carb-> free
XE 268H cam plus the whole valve train->free
Summit HEI distributor-> $150
Misc. things->$200???
I think it would be a good running motor for under 1500 bucks, I can easily do all the work assembling the motor. This swould be going in my cousin's 92 RS T-5 with 3.73's and he wants to do it on the cheap but have decent power. What do you guys think?
Old Mar 17, 2004 | 11:46 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
What exactly do you mean by "a connecting rod came loose"? The visual image that invokes doesn't sound very "ok" to me. If it was just a bearing getting spun or wiped out, both the crank journal and rod may have been wasted. The journal can be welded and re-ground, the rod is small journal so replacement may be an "issue".
187 heads are '87-later, and therefore not L69. I thought they were swirlports as well; if so you're killing the entire project. (I have a set of 416's in the Classifieds.)
I wouldn't use that carb, but that's my own little bias.
New valve springs would be very, very wise. 1.94" valves would help the poor thing breathe, but that's an added expense. Screw-in studs also highly recommended while you're at it.
Otherwise, it looks like a decent plan.
Old Mar 17, 2004 | 12:49 PM
ede's Avatar
ede
yeah first thing i thought of was cracked crank, main caps, or block. i'd sure inspect it good before i did much with it.
Old Mar 17, 2004 | 01:18 PM
GASGZLR's Avatar
You know what I think that they weren't 187's, but they did come off a Monte Carlo SS 1987 though, and I checked them and they are NOT swirl ports. 081's maybe then I'll double check when I get home. I was an L69 with Q-jet and I have the manifold too. I would just elongate the 4 center holes on the RPM intake.
Oh yeah five7 kid, the end cap came off cause the nuts on the bolts broke. The crank just bent up the rod. I know I should also get it checked for straightness.
Old Mar 17, 2004 | 02:41 PM
five7kid's Avatar
Use ARP bolts/nuts when you put it back together.
Old Mar 17, 2004 | 09:06 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Just an FYI,
Here's what happens when the OTHER end comes loose.
Old Mar 17, 2004 | 09:08 PM
AJ_92RS's Avatar
And the crank.
Old Mar 21, 2004 | 10:59 AM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
If it's a 67, it may have the large journal crank. If it is one of these you may want to just buy a crank kit for a 350 and turn it into one. (late late 327 had large journal cranks same as the 350)
just a thought.
Old Mar 22, 2004 | 09:04 AM
GASGZLR's Avatar
Nope, small journal 327. My crank and block aren't all jacked like the one AJ put in his pics. The seems to have been stopped right after it blew.
Pac J
May 17, 2020 10:44 AM
2012sergen11
Oct 13, 2015 07:38 PM
drumstixer
Sep 29, 2015 03:02 PM
tattmann
Sep 27, 2015 05:20 PM
84 TA NV
Sep 6, 2015 08:02 PM
